Date/Time: Thu, 02 May 2024 14:19:28 +0000
Import trades TO sierra ?
View Count: 2185
[2013-03-20 13:02:35] |
wwwingman - Posts: 185 |
Is it possible to IMPORT TO Sierra trades from another platform ? Using excel / text file / ... ? I use another DOM and would like to import my trades. I don't mind doing the file manually, but would like to see them for analyzing them and making a journal through Sierra. Thank you. W. |
[2013-03-20 17:38:21] |
This is not supported.
[2014-08-07 21:11:17] |
User56783 - Posts: 9 |
Hi. I know this is an old post, but I am looking for this functionality, too. Is this supported now or are there any plans to implement this? Thanks.
[2014-08-11 05:40:48] |
There are plans to do this but it is not something we have had time to spend on yet. It is considered very low priority. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
