Date/Time: Sun, 19 May 2024 05:24:15 +0000
New Computer (lost hard drive but have data saved from carbonite)
View Count: 728
[2015-12-19 16:50:18] |
Frank A Errico SR - Posts: 22 |
I Use the old woodies chart, which I downloaded from Sierra years ago. I have modified the chart over the years to my custom data. Carbonite downloaded the saved Sierra data as of December 15 to my new computer. Question : How do I get Serra chart back in the new computer and put the backed up data into. Thank You Frank |
[2015-12-19 17:40:15] |
Install Sierra Chart from this page: https://www.sierrachart.com/index.php?page=doc/download.php And follow the instructions here to copy the files from one installation of Sierra Chart to another: http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-29 14:32:43] |
Thank you Max and entire support staff !!!!!!!!!!!!!!!!!!!!!!!!! Back up and running Frank Errico |
