Date/Time: Wed, 15 May 2024 18:19:29 +0000
User Questions - symbols to use for charts
View Count: 637
[2015-12-18 20:48:48] |
Sierra Chart - Max - Posts: 5610 |
could you tell me please the symbols to use to create charts for:
A) SPY B) IWM C) QQQ thank you Sierra Chart Support |
[2015-12-18 21:00:23] |
We see you are a TransAct/Infinity user. These are stock symbols and for stock data you need to have a direct account. Follow the instructions here for this: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Did you require only historical data for the symbols? Or did you need real-time data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-18 21:00:58
