Date/Time: Sat, 18 May 2024 19:50:51 +0000
TRIX function call
View Count: 629
[2015-12-16 00:54:23] |
flyboy615 - Posts: 56 |
Hi, In you documentation you mention 2 function prototypes one of which is the following: SCFloatArrayRef TRIX(SCFloatArrayRef FloatArrayIn, SCSubgraphRef SubgraphOut, int Index, int Length); However the following piece of code complains about no instance of the s_sc::TRIX matching the argument list With autolooping turned off... int CurrentIndex = sc.Index-100; sc.TRIX( sc.Subgraph[0].Arrays[4], sc.Subgraph[0].Arrays[1],CurrentIndex, 6); Please advise. Thanks |
[2015-12-16 02:52:24] |
It requires a Subgraph and not a Float Array. You will need to use something like: sc.TRIX( sc.Subgraph[0].Arrays[4], sc.Subgraph[10], CurrentIndex, 6); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
