Date/Time: Sat, 18 May 2024 18:03:01 +0000
Linking Chartbopoks
View Count: 740
[2015-12-15 18:46:12] |
narcese - Posts: 58 |
Is the aforementioned feature possible? Thanks |
[2015-12-15 18:47:43] |
Specifically what did you want to link?
[2015-12-15 19:00:04] |
For example, I have 3 chartbooks open, Dly-Wkl and Monthly, 240 and 480, and 15-60 and 120 min. When I click on a FX pair on the quote board, such as aud-cad, can all chartbooks load up the same pair? I like to avoid clicking the quote board for the same pair for each chartbook. In effect, can the quote boards in different chartbooks be linked? Thanks |
[2015-12-15 19:04:09] |
This is actually possible in the latest prerelease now. It is supported for a single Quote Board when it is set to be always visible to link to charts in the active Chartbook.
[2015-12-15 19:10:24] |
I should download the prereleae from the help column? How would I set the quote board to always be visable to link charts in an active chartbook?
[2015-12-15 19:24:25] |
Yes. Download the Prerelease. Here are instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Here are the instructions to link across Chartbooks for the Quote Board: https://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#QuoteBoardLinkingAcrossChartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-15 20:46:35] |
I have downloaded prerelease 1339 and have linked all charts to the quote board, per instructions. The quote board does not have any activity, such as bid and ask etc. Additionally, monthly and weekly charts display a different price as the shorter timed charts. Thoughts? |
[2015-12-15 21:12:47] |
What is one of the symbols on the Quote Board that does not display any data? Make sure Sierra Chart is connected to the data feed with File >> Connect to Data Feed. Post an image of one of the Weekly Charts: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-15 21:28:37] |
I am unable to send screen shoot on this site. What is your e mail address?
Capture.PNG / V - Attached On 2015-12-15 21:24:21 UTC - Size: 157.37 KB - 225 views |
[2015-12-15 21:35:07] |
support _AT_ SierraChart.com
[2015-12-15 21:44:07] |
http://www.sierrachart.com/image.php?l=1450215817225.png
[2015-12-15 21:46:28] |
http://www.sierrachart.com/image.php?l=145021597297.png
[2015-12-15 21:48:58] |
Software version: 1339 | 2015-12-15 16:07:35 Uses New Spreadsheets | 2015-12-15 16:07:35 Usage end date: 2015-12-27 | 2015-12-15 16:07:35 Enabled for: Advanced Features. | 2015-12-15 16:07:35 Enabled for: Sierra Chart Historical Data Service. | 2015-12-15 16:07:35 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-12-15 16:07:35 Current selected Data/Trading service: SC Forex Data (FXCM) | 2015-12-15 16:07:35 Chart Update Interval: 500 | 2015-12-15 16:07:35 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-12-15 16:07:35 2015-12-15 16:07:35 Local computer time | 2015-12-15 16:07:35 2015-12-15 21:07:35 Local computer time in UTC | 2015-12-15 16:07:35 2015-12-15 16:07:35 Local computer time in SC Time Zone | 2015-12-15 16:07:35 2015-12-15 21:07:58 Server time in UTC | 2015-12-15 16:07:35 Local computer UTC time and Server UTC time difference: 24 seconds. | 2015-12-15 16:07:35 Program path: C:\SierraChart3\ | 2015-12-15 16:07:35 Data Files path: C:\SierraChart3\Data\ | 2015-12-15 16:07:35 OS Version Number: 6.1 | 2015-12-15 16:07:35 Locale Information: C | 2015-12-15 16:07:35 Checking for new symbol settings for fxcm | 2015-12-15 16:07:35 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-12-15 16:07:35 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2015-12-15 16:07:35 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2015-12-15 16:07:35 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2015-12-15 16:07:35 Requesting symbol settings for fxcm. Overwrite = off. | 2015-12-15 16:07:35 Symbol settings received. | 2015-12-15 16:07:36 Processed received symbol settings | 2015-12-15 16:07:36 Files to Open on Start up | Opening file: Dly Mnthly Wkly U S.cht | 2015-12-15 16:07:38 Files to Open on Start up | Opening file: 240-460-Dly US.cht | 2015-12-15 16:07:38 Files to Open on Start up | Opening file: 15-60-120 US.cht | 2015-12-15 16:07:38 Files to Open on Start up | Opening file: 720-960-Dly US.cht | 2015-12-15 16:07:38 Files to Open on Start up | Opening file: 5 15 240 Dly Mnthly Wkly.cht | 2015-12-15 16:07:39 Files to Open on Start up | Opening file: 240 480 720 960 Dly Wkly.cht | 2015-12-15 16:07:41 Files to Open on Start up | Opening file: London.cht | 2015-12-15 16:07:41 Files to Open on Start up | Opening file: Stalking 1.cht | 2015-12-15 16:07:42 Files to Open on Start up | Opening file: Stalking 2.cht | 2015-12-15 16:07:42 Files to Open on Start up | Opening file: Stalking 3.cht | 2015-12-15 16:07:42 Files to Open on Start up | Opening file: Stalking 4.cht | 2015-12-15 16:07:42 Files to Open on Start up | Opening file: Stalking 5.cht | 2015-12-15 16:07:42 Files to Open on Start up | Opening file: LIVE TRADES.cht | 2015-12-15 16:07:44 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2015-12-15 16:07:44 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2015-12-15 16:07:44 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2015-12-15 16:07:44 HD Request # 2 | Downloading Historical Daily chart data for CADJPY-BID. Starting date: 2015-12-14. Service: fxcm | 2015-12-15 16:07:44 HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2015-12-15 16:07:44 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-15 16:07:44 Intraday data recording state for symbol CADJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:44 Intraday data recording state for symbol AUDJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:46 Intraday data recording state for symbol NZDCAD-BID is set to download 'Pending'. | 2015-12-15 16:07:46 Intraday data recording state for symbol AUDCHF-BID is set to download 'Pending'. | 2015-12-15 16:07:46 Intraday data recording state for symbol CHFJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:49 Intraday data recording state for symbol EURAUD-BID is set to download 'Pending'. | 2015-12-15 16:07:49 Intraday data recording state for symbol NZDUSD-BID is set to download 'Pending'. | 2015-12-15 16:07:49 Intraday data recording state for symbol NZDJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:49 Intraday data recording state for symbol GBPAUD-BID is set to download 'Pending'. | 2015-12-15 16:07:50 Intraday data recording state for symbol USDCAD-BID is set to download 'Pending'. | 2015-12-15 16:07:50 Intraday data recording state for symbol GBPCHF-BID is set to download 'Pending'. | 2015-12-15 16:07:50 Intraday data recording state for symbol CADCHF-BID is set to download 'Pending'. | 2015-12-15 16:07:50 SC Forex Data (FXCM) | Connected to data server. | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GPGCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GPGCHF. ID: 1 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GPGCHF | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: USDSEK. ID: 3 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: USDSEK | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: AUDCAD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDCAD. ID: 4 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: AUDCAD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: AUDCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDCHF. ID: 6 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: AUDCHF | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: AUDJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDJPY. ID: 8 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: AUDJPY | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: AUDNZD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDNZD. ID: 10 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: AUDNZD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: AUDUSD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDUSD. ID: 12 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: AUDUSD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: CADCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: CADCHF. ID: 14 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: CADCHF | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: CADJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: CADJPY. ID: 16 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: CADJPY | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: CHFJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: CHFJPY. ID: 18 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: CHFJPY | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURAUD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURAUD. ID: 20 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURAUD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURCAD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURCAD. ID: 22 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURCAD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURCHF. ID: 24 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURCHF | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURGBP-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURGBP. ID: 26 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURGBP | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURJPY. ID: 28 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURJPY | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURNZD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURNZD. ID: 30 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURNZD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: EURUSD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: EURUSD. ID: 32 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: EURUSD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GBPAUD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPAUD. ID: 34 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GBPAUD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GBPCAD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPCAD. ID: 36 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GBPCAD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GBPCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPCHF. ID: 38 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GBPCHF | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GBPJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPJPY. ID: 40 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GBPJPY | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GBPNZD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPNZD. ID: 42 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GBPNZD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: GBPUSD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPUSD. ID: 44 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: GBPUSD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: NZDCAD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: NZDCAD. ID: 46 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: NZDCAD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: NZDCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: NZDCHF. ID: 48 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: NZDCHF | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: NZDJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: NZDJPY. ID: 50 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: NZDJPY | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: NZDUSD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: NZDUSD. ID: 52 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: NZDUSD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: USDCAD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: USDCAD. ID: 54 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: USDCAD | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: USDCHF-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: USDCHF. ID: 56 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: USDCHF | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: USDJPY-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: USDJPY. ID: 58 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: USDJPY | 2015-12-15 16:07:51 Starting updates for: USDSEK-BID | 2015-12-15 16:07:51 Supporting real-time market data updates for child symbol: USDSGD-BID | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Starting real-time market data updates for: USDSGD. ID: 61 | 2015-12-15 16:07:51 SC Forex Data (FXCM) | Subscribing to streaming market data in the service client is not supported. Symbol: USDSGD | 2015-12-15 16:07:51 Intraday data recording state for symbol AUDCHF-BID is set to download 'Pending'. | 2015-12-15 16:07:51 Historical Intraday data request for AUDCHF-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:51 Socket (4) | Connected. | 2015-12-15 16:07:52 HD Request # 2 | Sending historical data logon request message. | 2015-12-15 16:07:52 Intraday data recording state for symbol CHFJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for CHFJPY-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol EURAUD-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for EURAUD-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol NZDJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for NZDJPY-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol NZDUSD-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for NZDUSD-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol GBPAUD-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for GBPAUD-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol USDCAD-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for USDCAD-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol GBPCHF-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for GBPCHF-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 HD Request # 2 | Requesting historical Daily data starting at 2015-12-14. | 2015-12-15 16:07:52 Intraday data recording state for symbol CADCHF-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for CADCHF-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 Intraday data recording state for symbol CADJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:52 Historical Intraday data request for CADJPY-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:52 HD Request # 2 | Decompressing data. | 2015-12-15 16:07:52 HD Request # 2 | Receiving historical Daily data for CADJPY-BID starting at 2015-12-14 | 2015-12-15 16:07:52 Writing historical Daily data for CADJPY-BID to the file CADJPY-BID.dly | 2015-12-15 16:07:52 Socket (4) | Shutdown and closed. | 2015-12-15 16:07:52 The network socket for historical data has been closed. | 2015-12-15 16:07:52 HD Request # 2 | Received 2 records from 2015-12-14 00:00:00 to 2015-12-15 00:00:00 (2.0 days) and wrote 2 records for CADJPY-BID | 2015-12-15 16:07:52 HD Request # 2 | Daily download COMPLETE for CADJPY-BID. Completion time: 8s. Unique request ID: 1 | 2015-12-15 16:07:52 Removed historical data download ID 1 | 2015-12-15 16:07:52 HD Request # 3 | Downloading Intraday chart data for CADJPY-BID to the file CADJPY-BID.scid. Service: fxcm | 2015-12-15 16:07:52 HD Request # 3 | Download start Date-Time: 2015-12-15 16:07:32.000 | 2015-12-15 16:07:53 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2015-12-15 16:07:53 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-15 16:07:53 Socket (5) | Connected. | 2015-12-15 16:07:53 HD Request # 3 | Sending historical data logon request message. | 2015-12-15 16:07:53 Intraday data recording state for symbol NZDCAD-BID is set to download 'Pending'. | 2015-12-15 16:07:53 Historical Intraday data request for NZDCAD-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:53 Intraday data recording state for symbol AUDJPY-BID is set to download 'Pending'. | 2015-12-15 16:07:53 Historical Intraday data request for AUDJPY-BID is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-12-15 16:07:53 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:32. Record interval: 1. Symbol: CADJPY | 2015-12-15 16:07:53 HD Request # 3 | Decompressing data. | 2015-12-15 16:07:53 HD Request # 3 | Receiving Intraday data for CADJPY-BID starting at 2015-12-15 16:07:32 | 2015-12-15 16:07:53 HD Request # 3 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:32 | 2015-12-15 16:07:53 Socket (5) | Shutdown and closed. | 2015-12-15 16:07:53 The network socket for historical data has been closed. | 2015-12-15 16:07:53 HD Request # 3 | Received 11 records from 2015-12-15 16:07:32 to 2015-12-15 16:08:16 (44.0 seconds) and wrote 11 records for CADJPY-BID | 2015-12-15 16:07:54 HD Request # 3 | Intraday download COMPLETE for CADJPY-BID. Completion time: 2s. Unique request ID: 2 | 2015-12-15 16:07:54 Removed historical data download ID 2 | 2015-12-15 16:07:54 Real-time Intraday chart data file updates started for CADJPY-BID | 2015-12-15 16:07:54 HD Request # 4 | Downloading Intraday chart data for AUDJPY-BID to the file AUDJPY-BID.scid. Service: fxcm | 2015-12-15 16:07:54 HD Request # 4 | Download start Date-Time: 2015-12-15 16:07:19.000 | 2015-12-15 16:07:54 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2015-12-15 16:07:54 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-15 16:07:54 Socket (6) | Connected. | 2015-12-15 16:07:54 HD Request # 4 | Sending historical data logon request message. | 2015-12-15 16:07:54 CADJPY-BID Weekly #9 | Reloading chart. | 2015-12-15 16:07:54 CADJPY-BID Monthly #10 | Reloading chart. | 2015-12-15 16:07:54 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:19. Record interval: 1. Symbol: AUDJPY | 2015-12-15 16:07:55 HD Request # 4 | Decompressing data. | 2015-12-15 16:07:55 HD Request # 4 | Receiving Intraday data for AUDJPY-BID starting at 2015-12-15 16:07:19 | 2015-12-15 16:07:55 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:19 | 2015-12-15 16:07:55 Socket (6) | Shutdown and closed. | 2015-12-15 16:07:55 The network socket for historical data has been closed. | 2015-12-15 16:07:55 HD Request # 4 | Received 9 records from 2015-12-15 16:07:19 to 2015-12-15 16:08:13 (54.0 seconds) and wrote 9 records for AUDJPY-BID | 2015-12-15 16:07:55 HD Request # 4 | Intraday download COMPLETE for AUDJPY-BID. Completion time: 0s. Unique request ID: 3 | 2015-12-15 16:07:55 Removed historical data download ID 3 | 2015-12-15 16:07:55 Real-time Intraday chart data file updates started for AUDJPY-BID | 2015-12-15 16:07:55 HD Request # 5 | Downloading Intraday chart data for NZDCAD-BID to the file NZDCAD-BID.scid. Service: fxcm | 2015-12-15 16:07:55 HD Request # 5 | Download start Date-Time: 2015-12-15 16:07:23.000 | 2015-12-15 16:07:55 HD Request # 5 | Using server: ds5.sierracharts.com port 10149 | 2015-12-15 16:07:55 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-15 16:07:55 Socket (7) | Connected. | 2015-12-15 16:07:55 HD Request # 5 | Sending historical data logon request message. | 2015-12-15 16:07:55 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:23. Record interval: 1. Symbol: NZDCAD | 2015-12-15 16:07:55 HD Request # 5 | Decompressing data. | 2015-12-15 16:07:55 HD Request # 5 | Receiving Intraday data for NZDCAD-BID starting at 2015-12-15 16:07:23 | 2015-12-15 16:07:55 HD Request # 5 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:23 | 2015-12-15 16:07:55 Socket (7) | Shutdown and closed. | 2015-12-15 16:07:55 The network socket for historical data has been closed. | 2015-12-15 16:07:55 HD Request # 5 | Received 15 records from 2015-12-15 16:07:23 to 2015-12-15 16:08:19 (56.0 seconds) and wrote 15 records for NZDCAD-BID | 2015-12-15 16:07:56 HD Request # 5 | Intraday download COMPLETE for NZDCAD-BID. Completion time: 1s. Unique request ID: 4 | 2015-12-15 16:07:56 Removed historical data download ID 4 | 2015-12-15 16:07:56 Real-time Intraday chart data file updates started for NZDCAD-BID | 2015-12-15 16:07:56 HD Request # 6 | Downloading Historical Daily chart data for AUDCHF-BID. Starting date: 2015-12-14. Service: fxcm | 2015-12-15 16:07:56 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2015-12-15 16:07:56 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-15 16:07:56 Socket (8) | Connected. | 2015-12-15 16:07:56 HD Request # 6 | Sending historical data logon request message. | 2015-12-15 16:07:56 HD Request # 6 | Requesting historical Daily data starting at 2015-12-14. | 2015-12-15 16:07:56 HD Request # 6 | Decompressing data. | 2015-12-15 16:07:56 HD Request # 6 | Receiving historical Daily data for AUDCHF-BID starting at 2015-12-14 | 2015-12-15 16:07:56 Writing historical Daily data for AUDCHF-BID to the file AUDCHF-BID.dly | 2015-12-15 16:07:56 Socket (8) | Shutdown and closed. | 2015-12-15 16:07:56 The network socket for historical data has been closed. | 2015-12-15 16:07:56 HD Request # 6 | Received 2 records from 2015-12-14 00:00:00 to 2015-12-15 00:00:00 (2.0 days) and wrote 2 records for AUDCHF-BID | 2015-12-15 16:07:56 HD Request # 6 | Daily download COMPLETE for AUDCHF-BID. Completion time: 0s. Unique request ID: 5 | 2015-12-15 16:07:56 Removed historical data download ID 5 | 2015-12-15 16:07:56 HD Request # 7 | Downloading Intraday chart data for AUDCHF-BID to the file AUDCHF-BID.scid. Service: fxcm | 2015-12-15 16:07:56 HD Request # 7 | Download start Date-Time: 2015-12-15 16:07:16.000 | 2015-12-15 16:07:57 HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2015-12-15 16:07:57 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-15 16:07:57 Socket (9) | Connected. | 2015-12-15 16:07:57 HD Request # 7 | Sending historical data logon request message. | 2015-12-15 16:07:57 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:16. Record interval: 1. Symbol: AUDCHF | 2015-12-15 16:07:57 HD Request # 7 | Decompressing data. | 2015-12-15 16:07:57 HD Request # 7 | Receiving Intraday data for AUDCHF-BID starting at 2015-12-15 16:07:16 | 2015-12-15 16:07:57 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:16 | 2015-12-15 16:07:57 Socket (9) | Shutdown and closed. | 2015-12-15 16:07:57 The network socket for historical data has been closed. | 2015-12-15 16:07:57 HD Request # 7 | Received 8 records from 2015-12-15 16:07:16 to 2015-12-15 16:08:20 (64.0 seconds) and wrote 8 records for AUDCHF-BID | 2015-12-15 16:07:58 HD Request # 7 | Intraday download COMPLETE for AUDCHF-BID. Completion time: 2s. Unique request ID: 6 | 2015-12-15 16:07:58 Removed historical data download ID 6 | 2015-12-15 16:07:58 Real-time Intraday chart data file updates started for AUDCHF-BID | 2015-12-15 16:07:58 HD Request # 8 | Downloading Intraday chart data for CHFJPY-BID to the file CHFJPY-BID.scid. Service: fxcm | 2015-12-15 16:07:58 HD Request # 8 | Download start Date-Time: 2015-12-15 16:07:21.000 | 2015-12-15 16:07:58 HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2015-12-15 16:07:58 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-15 16:07:58 Socket (10) | Connected. | 2015-12-15 16:07:59 HD Request # 8 | Sending historical data logon request message. | 2015-12-15 16:07:59 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:21. Record interval: 1. Symbol: CHFJPY | 2015-12-15 16:07:59 AUDCHF-BID Weekly #9 | Reloading chart. | 2015-12-15 16:07:59 HD Request # 8 | Decompressing data. | 2015-12-15 16:07:59 HD Request # 8 | Receiving Intraday data for CHFJPY-BID starting at 2015-12-15 16:07:21 | 2015-12-15 16:07:59 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:21 | 2015-12-15 16:07:59 Socket (10) | Shutdown and closed. | 2015-12-15 16:07:59 The network socket for historical data has been closed. | 2015-12-15 16:07:59 HD Request # 8 | Received 7 records from 2015-12-15 16:07:21 to 2015-12-15 16:08:10 (49.0 seconds) and wrote 7 records for CHFJPY-BID | 2015-12-15 16:07:59 HD Request # 8 | Intraday download COMPLETE for CHFJPY-BID. Completion time: 1s. Unique request ID: 7 | 2015-12-15 16:07:59 Removed historical data download ID 7 | 2015-12-15 16:07:59 Real-time Intraday chart data file updates started for CHFJPY-BID | 2015-12-15 16:07:59 HD Request # 9 | Downloading Historical Daily chart data for CHFJPY-BID. Starting date: 2015-12-14. Service: fxcm | 2015-12-15 16:07:59 HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2015-12-15 16:07:59 AUDCHF-BID Monthly #10 | Reloading chart. | 2015-12-15 16:07:59 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-15 16:07:59 Socket (11) | Connected. | 2015-12-15 16:07:59 HD Request # 9 | Sending historical data logon request message. | 2015-12-15 16:07:59 HD Request # 9 | Requesting historical Daily data starting at 2015-12-14. | 2015-12-15 16:07:59 HD Request # 9 | Decompressing data. | 2015-12-15 16:07:59 HD Request # 9 | Receiving historical Daily data for CHFJPY-BID starting at 2015-12-14 | 2015-12-15 16:07:59 Writing historical Daily data for CHFJPY-BID to the file CHFJPY-BID.dly | 2015-12-15 16:07:59 Socket (11) | Shutdown and closed. | 2015-12-15 16:07:59 The network socket for historical data has been closed. | 2015-12-15 16:07:59 HD Request # 9 | Received 2 records from 2015-12-14 00:00:00 to 2015-12-15 00:00:00 (2.0 days) and wrote 2 records for CHFJPY-BID | 2015-12-15 16:07:59 HD Request # 9 | Daily download COMPLETE for CHFJPY-BID. Completion time: 0s. Unique request ID: 8 | 2015-12-15 16:07:59 Removed historical data download ID 8 | 2015-12-15 16:07:59 HD Request # 10 | Downloading Intraday chart data for EURAUD-BID to the file EURAUD-BID.scid. Service: fxcm | 2015-12-15 16:07:59 HD Request # 10 | Download start Date-Time: 2015-12-15 16:07:31.000 | 2015-12-15 16:07:59 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2015-12-15 16:07:59 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-15 16:07:59 CHFJPY-BID Weekly #8 | Reloading chart. | 2015-12-15 16:07:59 Socket (12) | Connected. | 2015-12-15 16:07:59 HD Request # 10 | Sending historical data logon request message. | 2015-12-15 16:07:59 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:31. Record interval: 1. Symbol: EURAUD | 2015-12-15 16:07:59 HD Request # 10 | Decompressing data. | 2015-12-15 16:07:59 HD Request # 10 | Receiving Intraday data for EURAUD-BID starting at 2015-12-15 16:07:31 | 2015-12-15 16:07:59 HD Request # 10 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:31 | 2015-12-15 16:07:59 Socket (12) | Shutdown and closed. | 2015-12-15 16:07:59 The network socket for historical data has been closed. | 2015-12-15 16:07:59 HD Request # 10 | Received 12 records from 2015-12-15 16:07:31 to 2015-12-15 16:08:22 (51.0 seconds) and wrote 12 records for EURAUD-BID | 2015-12-15 16:07:59 HD Request # 10 | Intraday download COMPLETE for EURAUD-BID. Completion time: 0s. Unique request ID: 9 | 2015-12-15 16:07:59 Removed historical data download ID 9 | 2015-12-15 16:07:59 Real-time Intraday chart data file updates started for EURAUD-BID | 2015-12-15 16:07:59 HD Request # 11 | Downloading Historical Daily chart data for EURAUD-BID. Starting date: 2015-12-14. Service: fxcm | 2015-12-15 16:07:59 HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2015-12-15 16:07:59 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-15 16:07:59 Socket (13) | Connected. | 2015-12-15 16:08:00 HD Request # 11 | Sending historical data logon request message. | 2015-12-15 16:08:00 CHFJPY-BID Weekly #1 | Reloading chart. | 2015-12-15 16:08:00 HD Request # 11 | Requesting historical Daily data starting at 2015-12-14. | 2015-12-15 16:08:00 HD Request # 11 | Decompressing data. | 2015-12-15 16:08:00 HD Request # 11 | Receiving historical Daily data for EURAUD-BID starting at 2015-12-14 | 2015-12-15 16:08:00 Writing historical Daily data for EURAUD-BID to the file EURAUD-BID.dly | 2015-12-15 16:08:00 Socket (13) | Shutdown and closed. | 2015-12-15 16:08:00 The network socket for historical data has been closed. | 2015-12-15 16:08:00 HD Request # 11 | Received 2 records from 2015-12-14 00:00:00 to 2015-12-15 00:00:00 (2.0 days) and wrote 2 records for EURAUD-BID | 2015-12-15 16:08:00 HD Request # 11 | Daily download COMPLETE for EURAUD-BID. Completion time: 1s. Unique request ID: 10 | 2015-12-15 16:08:00 Removed historical data download ID 10 | 2015-12-15 16:08:00 HD Request # 12 | Downloading Intraday chart data for NZDUSD-BID to the file NZDUSD-BID.scid. Service: fxcm | 2015-12-15 16:08:00 HD Request # 12 | Download start Date-Time: 2015-12-15 16:07:25.000 | 2015-12-15 16:08:00 HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2015-12-15 16:08:00 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-15 16:08:00 Socket (14) | Connected. | 2015-12-15 16:08:00 HD Request # 12 | Sending historical data logon request message. | 2015-12-15 16:08:00 EURAUD-BID Weekly #7 | Reloading chart. | 2015-12-15 16:08:00 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:25. Record interval: 1. Symbol: NZDUSD | 2015-12-15 16:08:00 HD Request # 12 | Decompressing data. | 2015-12-15 16:08:00 HD Request # 12 | Receiving Intraday data for NZDUSD-BID starting at 2015-12-15 16:07:25 | 2015-12-15 16:08:00 HD Request # 12 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:25 | 2015-12-15 16:08:00 Socket (14) | Shutdown and closed. | 2015-12-15 16:08:00 The network socket for historical data has been closed. | 2015-12-15 16:08:00 HD Request # 12 | Received 6 records from 2015-12-15 16:07:25 to 2015-12-15 16:08:21 (56.0 seconds) and wrote 6 records for NZDUSD-BID | 2015-12-15 16:08:00 HD Request # 12 | Intraday download COMPLETE for NZDUSD-BID. Completion time: 0s. Unique request ID: 11 | 2015-12-15 16:08:00 Removed historical data download ID 11 | 2015-12-15 16:08:00 Real-time Intraday chart data file updates started for NZDUSD-BID | 2015-12-15 16:08:00 HD Request # 13 | Downloading Intraday chart data for NZDJPY-BID to the file NZDJPY-BID.scid. Service: fxcm | 2015-12-15 16:08:00 HD Request # 13 | Download start Date-Time: 2015-12-15 16:07:20.000 | 2015-12-15 16:08:00 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2015-12-15 16:08:00 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-15 16:08:00 EURAUD-BID Monthly #8 | Reloading chart. | 2015-12-15 16:08:00 Socket (15) | Connected. | 2015-12-15 16:08:00 HD Request # 13 | Sending historical data logon request message. | 2015-12-15 16:08:00 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:20. Record interval: 1. Symbol: NZDJPY | 2015-12-15 16:08:00 HD Request # 13 | Decompressing data. | 2015-12-15 16:08:00 HD Request # 13 | Receiving Intraday data for NZDJPY-BID starting at 2015-12-15 16:07:20 | 2015-12-15 16:08:00 HD Request # 13 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:20 | 2015-12-15 16:08:00 Socket (15) | Shutdown and closed. | 2015-12-15 16:08:00 The network socket for historical data has been closed. | 2015-12-15 16:08:00 HD Request # 13 | Received 8 records from 2015-12-15 16:07:20 to 2015-12-15 16:08:21 (61.0 seconds) and wrote 8 records for NZDJPY-BID | 2015-12-15 16:08:00 HD Request # 13 | Intraday download COMPLETE for NZDJPY-BID. Completion time: 0s. Unique request ID: 12 | 2015-12-15 16:08:00 Removed historical data download ID 12 | 2015-12-15 16:08:00 Real-time Intraday chart data file updates started for NZDJPY-BID | 2015-12-15 16:08:00 HD Request # 14 | Downloading Intraday chart data for GBPAUD-BID to the file GBPAUD-BID.scid. Service: fxcm | 2015-12-15 16:08:00 HD Request # 14 | Download start Date-Time: 2015-12-15 16:07:32.000 | 2015-12-15 16:08:00 HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2015-12-15 16:08:00 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-15 16:08:00 Socket (16) | Connected. | 2015-12-15 16:08:00 HD Request # 14 | Sending historical data logon request message. | 2015-12-15 16:08:00 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:32. Record interval: 1. Symbol: GBPAUD | 2015-12-15 16:08:00 HD Request # 14 | Decompressing data. | 2015-12-15 16:08:00 HD Request # 14 | Receiving Intraday data for GBPAUD-BID starting at 2015-12-15 16:07:32 | 2015-12-15 16:08:00 HD Request # 14 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:32 | 2015-12-15 16:08:00 Socket (16) | Shutdown and closed. | 2015-12-15 16:08:00 The network socket for historical data has been closed. | 2015-12-15 16:08:00 HD Request # 14 | Received 17 records from 2015-12-15 16:07:32 to 2015-12-15 16:08:22 (50.0 seconds) and wrote 17 records for GBPAUD-BID | 2015-12-15 16:08:00 HD Request # 14 | Intraday download COMPLETE for GBPAUD-BID. Completion time: 0s. Unique request ID: 13 | 2015-12-15 16:08:00 Removed historical data download ID 13 | 2015-12-15 16:08:00 Real-time Intraday chart data file updates started for GBPAUD-BID | 2015-12-15 16:08:00 HD Request # 15 | Downloading Intraday chart data for USDCAD-BID to the file USDCAD-BID.scid. Service: fxcm | 2015-12-15 16:08:00 HD Request # 15 | Download start Date-Time: 2015-12-15 16:07:28.000 | 2015-12-15 16:08:00 HD Request # 15 | Using server: ds3.sierracharts.com port 10149 | 2015-12-15 16:08:00 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-15 16:08:00 Socket (17) | Connected. | 2015-12-15 16:08:00 HD Request # 15 | Sending historical data logon request message. | 2015-12-15 16:08:00 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:28. Record interval: 1. Symbol: USDCAD | 2015-12-15 16:08:00 HD Request # 15 | Decompressing data. | 2015-12-15 16:08:00 HD Request # 15 | Receiving Intraday data for USDCAD-BID starting at 2015-12-15 16:07:28 | 2015-12-15 16:08:00 HD Request # 15 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:28 | 2015-12-15 16:08:00 Socket (17) | Shutdown and closed. | 2015-12-15 16:08:00 The network socket for historical data has been closed. | 2015-12-15 16:08:00 HD Request # 15 | Received 25 records from 2015-12-15 16:07:28 to 2015-12-15 16:08:23 (55.0 seconds) and wrote 25 records for USDCAD-BID | 2015-12-15 16:08:01 HD Request # 15 | Intraday download COMPLETE for USDCAD-BID. Completion time: 0s. Unique request ID: 14 | 2015-12-15 16:08:01 Removed historical data download ID 14 | 2015-12-15 16:08:01 Real-time Intraday chart data file updates started for USDCAD-BID | 2015-12-15 16:08:01 HD Request # 16 | Downloading Intraday chart data for GBPCHF-BID to the file GBPCHF-BID.scid. Service: fxcm | 2015-12-15 16:08:01 HD Request # 16 | Download start Date-Time: 2015-12-15 16:07:31.000 | 2015-12-15 16:08:01 HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2015-12-15 16:08:01 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-15 16:08:01 Socket (18) | Connected. | 2015-12-15 16:08:01 HD Request # 16 | Sending historical data logon request message. | 2015-12-15 16:08:01 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:31. Record interval: 1. Symbol: GBPCHF | 2015-12-15 16:08:01 HD Request # 16 | Decompressing data. | 2015-12-15 16:08:01 HD Request # 16 | Receiving Intraday data for GBPCHF-BID starting at 2015-12-15 16:07:31 | 2015-12-15 16:08:01 HD Request # 16 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:31 | 2015-12-15 16:08:01 Socket (18) | Shutdown and closed. | 2015-12-15 16:08:01 The network socket for historical data has been closed. | 2015-12-15 16:08:01 HD Request # 16 | Received 13 records from 2015-12-15 16:07:31 to 2015-12-15 16:08:10 (39.0 seconds) and wrote 13 records for GBPCHF-BID | 2015-12-15 16:08:01 HD Request # 16 | Intraday download COMPLETE for GBPCHF-BID. Completion time: 0s. Unique request ID: 15 | 2015-12-15 16:08:01 Removed historical data download ID 15 | 2015-12-15 16:08:01 Real-time Intraday chart data file updates started for GBPCHF-BID | 2015-12-15 16:08:01 HD Request # 17 | Downloading Intraday chart data for CADCHF-BID to the file CADCHF-BID.scid. Service: fxcm | 2015-12-15 16:08:01 HD Request # 17 | Download start Date-Time: 2015-12-15 16:07:23.000 | 2015-12-15 16:08:01 HD Request # 17 | Using server: ds5.sierracharts.com port 10149 | 2015-12-15 16:08:01 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-15 16:08:01 Socket (19) | Connected. | 2015-12-15 16:08:01 HD Request # 17 | Sending historical data logon request message. | 2015-12-15 16:08:01 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:23. Record interval: 1. Symbol: CADCHF | 2015-12-15 16:08:01 HD Request # 17 | Decompressing data. | 2015-12-15 16:08:01 HD Request # 17 | Receiving Intraday data for CADCHF-BID starting at 2015-12-15 16:07:23 | 2015-12-15 16:08:01 HD Request # 17 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:23 | 2015-12-15 16:08:01 Socket (19) | Shutdown and closed. | 2015-12-15 16:08:01 The network socket for historical data has been closed. | 2015-12-15 16:08:01 HD Request # 17 | Received 10 records from 2015-12-15 16:07:23 to 2015-12-15 16:08:15 (52.0 seconds) and wrote 10 records for CADCHF-BID | 2015-12-15 16:08:01 HD Request # 17 | Intraday download COMPLETE for CADCHF-BID. Completion time: 0s. Unique request ID: 16 | 2015-12-15 16:08:01 Removed historical data download ID 16 | 2015-12-15 16:08:01 Real-time Intraday chart data file updates started for CADCHF-BID | 2015-12-15 16:08:01 CADJPY-BID Weekly #9 | Reloading chart. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 240 Min #2 | Reloading chart. | 2015-12-15 16:08:03 CADJPY-BID Monthly #10 | Reloading chart. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 240 Min #1 | Reloading chart. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 120 Min #8 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 1 Day #13 | Reloading chart. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 120 Min #4 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 120 Min #11 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 15 Min #5 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 240 Min #12 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 30 Min #6 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 60 Min #7 | Reloading chart. | 2015-12-15 16:08:03 CADJPY-BID/CADJPY 480 Min #14 | Reloading chart. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 LoadIntradayData: Load canceled. | 2015-12-15 16:08:03 CHFJPY-BID/CHFJPY 240 Min #2 | Reloading chart. | 2015-12-15 16:08:03 CHFJPY-BID/CHFJPY 240 Min #1 | Reloading chart. | 2015-12-15 16:08:03 CHFJPY-BID/CHFJPY 120 Min #8 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 1 Day #13 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 120 Min #4 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 120 Min #11 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 15 Min #5 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 240 Min #12 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 30 Min #6 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 60 Min #7 | Reloading chart. | 2015-12-15 16:08:04 CHFJPY-BID/CHFJPY 480 Min #14 | Reloading chart. | 2015-12-15 16:08:04 Remote instance connected: C:\SierraChart\SierraChart.exe | 2015-12-15 16:11:06 CHFJPY-BID Weekly #9 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 240 Min #2 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID Monthly #10 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 240 Min #1 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 120 Min #8 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 1 Day #13 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 120 Min #4 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 120 Min #11 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 15 Min #5 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 240 Min #12 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 30 Min #6 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 60 Min #7 | Reloading chart. | 2015-12-15 16:30:35 CHFJPY-BID/CHFJPY 480 Min #14 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 240 Min #2 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 240 Min #1 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 120 Min #8 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 1 Day #13 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 120 Min #4 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 120 Min #11 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 15 Min #5 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 240 Min #12 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 30 Min #6 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 60 Min #7 | Reloading chart. | 2015-12-15 16:30:35 AUDCAD-BID/AUDCAD 480 Min #14 | Reloading chart. | 2015-12-15 16:30:35 HD Request # 18 | Downloading Historical Daily chart data for AUDCAD-BID. Starting date: 2015-12-14. Service: fxcm | 2015-12-15 16:30:36 HD Request # 18 | Using server: ds3.sierracharts.com port 10149 | 2015-12-15 16:30:36 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-15 16:30:36 Intraday data recording state for symbol AUDCAD-BID is set to download 'Pending'. | 2015-12-15 16:30:36 Socket (31) | Connected. | 2015-12-15 16:30:36 HD Request # 18 | Sending historical data logon request message. | 2015-12-15 16:30:36 HD Request # 18 | Requesting historical Daily data starting at 2015-12-14. | 2015-12-15 16:30:36 HD Request # 18 | Decompressing data. | 2015-12-15 16:30:36 HD Request # 18 | Receiving historical Daily data for AUDCAD-BID starting at 2015-12-14 | 2015-12-15 16:30:36 Writing historical Daily data for AUDCAD-BID to the file AUDCAD-BID.dly | 2015-12-15 16:30:36 Socket (31) | Shutdown and closed. | 2015-12-15 16:30:36 The network socket for historical data has been closed. | 2015-12-15 16:30:36 HD Request # 18 | Received 2 records from 2015-12-14 00:00:00 to 2015-12-15 00:00:00 (2.0 days) and wrote 2 records for AUDCAD-BID | 2015-12-15 16:30:36 HD Request # 18 | Daily download COMPLETE for AUDCAD-BID. Completion time: 0s. Unique request ID: 29 | 2015-12-15 16:30:36 Removed historical data download ID 29 | 2015-12-15 16:30:36 HD Request # 19 | Downloading Intraday chart data for AUDCAD-BID to the file AUDCAD-BID.scid. Service: fxcm | 2015-12-15 16:30:36 HD Request # 19 | Download start Date-Time: 2015-12-15 16:07:30.000 | 2015-12-15 16:30:36 HD Request # 19 | Using server: ds4.sierracharts.com port 10149 | 2015-12-15 16:30:36 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-15 16:30:36 Socket (32) | Connected. | 2015-12-15 16:30:36 HD Request # 19 | Sending historical data logon request message. | 2015-12-15 16:30:36 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2015-12-15 16:07:30. Record interval: 1. Symbol: AUDCAD | 2015-12-15 16:30:36 HD Request # 19 | Decompressing data. | 2015-12-15 16:30:36 HD Request # 19 | Receiving Intraday data for AUDCAD-BID starting at 2015-12-15 16:07:30 | 2015-12-15 16:30:36 HD Request # 19 | Timestamp of first Intraday data file record written: 2015-12-15 16:07:30 | 2015-12-15 16:30:36 Socket (32) | Shutdown and closed. | 2015-12-15 16:30:36 The network socket for historical data has been closed. | 2015-12-15 16:30:36 HD Request # 19 | Received 454 records from 2015-12-15 16:07:30 to 2015-12-15 16:30:58 (23.5 minutes) and wrote 454 records for AUDCAD-BID | 2015-12-15 16:30:36 HD Request # 19 | Intraday download COMPLETE for AUDCAD-BID. Completion time: 0s. Unique request ID: 30 | 2015-12-15 16:30:36 Removed historical data download ID 30 | 2015-12-15 16:30:36 Real-time Intraday chart data file updates started for AUDCAD-BID | 2015-12-15 16:30:36 AUDCAD-BID Weekly #9 | Reloading chart. | 2015-12-15 16:30:36 AUDCAD-BID Monthly #10 | Reloading chart. | 2015-12-15 16:30:36 Uploaded an image to the server. Request ID: 1 | 2015-12-15 16:42:10 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-12-15 16:42:10 HTTP connection to www.sierrachart.com:80 (39) | Connected. | 2015-12-15 16:42:11 HTTP connection to www.sierrachart.com:80 (39) | Closed. No error. | 2015-12-15 16:42:17 HTTP connection to www.sierrachart.com:80 (39) | Shutdown and closed. | 2015-12-15 16:42:17 Uploaded an image to the server. Request ID: 2 | 2015-12-15 16:43:12 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-12-15 16:43:12 HTTP connection to www.sierrachart.com:80 (40) | Connected. | 2015-12-15 16:43:12 HTTP connection to www.sierrachart.com:80 (40) | Closed. No error. | 2015-12-15 16:43:18 HTTP connection to www.sierrachart.com:80 (40) | Shutdown and closed. | 2015-12-15 16:43:18 Uploaded an image to the server. Request ID: 3 | 2015-12-15 16:45:47 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-12-15 16:45:47 HTTP connection to www.sierrachart.com:80 (43) | Connected. | 2015-12-15 16:45:47 HTTP connection to www.sierrachart.com:80 (43) | Closed. No error. | 2015-12-15 16:45:53 HTTP connection to www.sierrachart.com:80 (43) | Shutdown and closed. | 2015-12-15 16:45:53 Cannot import symbols. File does not exist: C:\SierraChart3\Data\N.SymbolList | 2015-12-15 16:47:44 * |
[2015-12-15 21:59:47] |
We see what the problem is here. Follow the instructions here to update the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings If you have set up any custom Session Times those will not change after updating the Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-15 22:09:00] |
BY updating the Global symbol setting the quote board is now populated but all chartbooks are not showing selected symbol. Chartbook only populates desired symbol if chartbook is open.
[2015-12-15 22:39:31] |
Yes this is correct. Selecting a Symbol line on the Quote Board is only going to affect the charts in the active Chartbook with the same Link Number as the Quote Board.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-15 22:39:52
[2015-12-15 22:50:40] |
I miss understood, you cannot link chartbooks with 1 quote board? This is a feature we need, it is long overdue.
[2015-12-15 23:00:47] |
We can add this capability as an option. We will do that.
[2015-12-15 23:37:10] |
It would be a huge time saver. Thanks for being workable.
