Date/Time: Sat, 18 May 2024 21:55:31 +0000
Re: Auto-Coloring in subgraphs
View Count: 960
[2015-12-15 14:05:31] |
User170575 - Posts: 221 |
Good morning, Regarding the auto-coloring using the "based on slope" feature, is there a way to use this as an alert without using the formula in the alerts tab? If you have to use the formula in the alerts tab---would you mind sharing the formula for the slope? Many thanks, Cy |
[2015-12-15 18:49:26] |
Refer to example 8 here: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#FormulaExamples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
