Date/Time: Sat, 18 May 2024 16:54:56 +0000
STOCK TRADING WORKSPACES
View Count: 602
[2015-12-15 02:15:21] |
AP - Posts: 117 |
Hi - Just a question on how best to customize a stock trading (not futures trading) appropriate work space. Like I know what I want but I thought if you guys already have any templates to suggest for stock trading. 1. For instance, Inifinity Futures (an entity unrelated to you though) have a bunch of such template and videos guiding how best to set up a futures work space on SC - do you know of anybody else more focused on stock trading? 2. Do you have any videos on how best to use the scanning feature on SC? |
[2015-12-15 04:36:43] |
1. No. 2. No. There is only written documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
