Date/Time: Sun, 19 May 2024 01:39:42 +0000
COPY CHART DRAWINGS
View Count: 590
[2015-12-15 01:42:24] |
AP - Posts: 117 |
Hi - Please need help here - In trying to use this function under the Advanced Settings 2 under Chart Settings - Copy Chart Drawings From Chart# I see that the levels in the source chart where drawings are drawn by me are not exactly depicted in the target chart where drawings are copied by the system with the use of above mentioned functionality. In fact it is way off in a couple of cases. I have checked it thoroughly both chart has extended hours data+download weekend data as well - of course same symbols. Although this does not happen with all the drawings, I must say but it is happening with a couple of them. Any reason this happens and how can I have it reflect right levels - please. |
[2015-12-15 03:40:41] |
Refer to this Help Topic: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html We would expect this would only be a problem with sloping Lines and not Horizontal Lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
