Date/Time: Sat, 18 May 2024 18:02:18 +0000
Want to transfer my tool configs to a new computer
View Count: 940
[2015-12-14 23:24:59] |
spartan forecasts admin - Posts: 21 |
In the past when switching computers I just copied my Sierra3.cfg file to c:/SierraChart to get the same tool configs and global settings. However it is not working this time. Did I miss something?
[2015-12-14 23:38:49] |
Yes you are correct, that is the file. However, make sure that the copy of Sierra Chart you are copying the Sierra3.cfg file to, that it is not running at the time you are copying the file. That file definitely does contain the Drawing Tool configurations and other Global Settings. If you need more help let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-14 23:39:24
