Date/Time: Sat, 18 May 2024 22:03:35 +0000
Colors for compact tools window
View Count: 650
[2015-12-14 18:50:06] |
User35326 - Posts: 57 |
SC: How do I change the colors for the open, high, low and last in the compact tools window? Right now the open is in black, the high is in light green, the low is in black and the last is in red. I would like all 4, the open, high, low and last to be the same color, which is the same color i set for each chart using chart settings > colors and widths for chart objects > chart text. Thanks in advance. |
[2015-12-14 19:08:58] |
We need to understand this better. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-14 20:51:04] |
SC: Here is a screen image. The thing I have noticed is when Renko charts are used with my latest update to version 1335 and a new chart is built then the open, high, low and last colors in the horizontal compact tools are as shown below. I would like them to be the same color as the y axis and the date and the time as shown in the screenshot below. If a minute chart is used, then the open, high, low and last are all the same color which happens to be the same color as the chart text. Please inform me how to fix this when using a renko chart, as shown below. Note, when using a minute chart then all the colors in the compact tools value window are the same. Here is the screen shot with the compact tools value window on a renko chart. http://www.sierrachart.com/image.php?l=1450126446333.png Here is a screen shot with the compact tools value window on a minute chart http://www.sierrachart.com/image.php?l=1450126610797.png I changed nothing except went from a minute chart to a renko chart. Your software somehow made the change. Note how the colors for open, high, low and last are different on the two screen shots. Hopefully, that is enough information now for you to see what I am experiencing. How do I get the colors to all be the same in the compact tools window for a renko chart? Thanks and for what my opinion is worth, I think your charts are the best. Date Time Of Last Edit: 2015-12-14 21:01:31
[2015-12-14 21:37:51] |
Not sure why no one else pointed this out previously. This will be solved in the next release. The coloring of the Subgraph values to the Subgraph colors rather than to the Chart Text color does not appear to be anything new. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
