Date/Time: Tue, 07 May 2024 10:27:32 +0000
Automatic Trading
View Count: 1343
[2013-06-23 06:58:56] |
User35471 - Posts: 6 |
Hello, I' m using ASCIL and I have read that with the s_SCNewOrder structure I can do automatic trading, but only in the chart than is activated my custom study. Is it correct? Instead I want to do it in two charts enabling the study in a single charrt. Can I do it? Thanks
[2013-06-23 08:27:38] |
This can be done. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ACSILRefOtherTimeFrames.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
