Date/Time: Sun, 19 May 2024 05:23:30 +0000
Chart Settings Issue
View Count: 797
[2015-12-10 15:07:20] |
conr - Posts: 204 |
I am charting ES futures with the Auto Rollover Futures Symbol checked and Continuous Futures Contract-Date Rule Rollover, Back Adjusted setting. Using Sierra data. I have my session start time set for 8:30 and end at 15:15. Yesterday I shut down Sierra and reopened this morning so the March contract would be charting. The problem I am encountering EVERY time I do this for the roll, the session time reverts back to default and I have to reset. Why is this happening? Thank you. |
[2015-12-10 17:51:27] |
The solution to this is explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-10 18:49:29] |
conr - Posts: 204 |
Okay thanks. Do I use ES?# as the symbol in the window to the left of the session times?
[2015-12-10 18:55:27] |
Yes, that is the correct symbol pattern.
[2019-08-02 18:33:59] |
Chad - Posts: 231 |
Hi SCE, is there a Global Setting for Continuous Contract rollover method that I can spec so I don't have to go to Chart Settings>>Advanced Settings and specify for each market? Maybe I'm overlooking the documentation... Is this setting (and others) affected when updated SC to the latest version? |
[2019-08-02 18:52:10] |
No definitely not. You have to set this on individual charts. Is this setting (and others) affected when updated SC to the latest version? No.
