Date/Time: Sun, 05 May 2024 09:59:50 +0000
[User Discussion] - Am trying to add spreadsheet study for WeissWave solution...
View Count: 1832
[2013-06-22 19:08:31] |
reggytrades - Posts: 29 |
Saved the files to "SierraChart/Data" folder. Then attempted to open the spreadsheet file. The file shows in xplorer2, but the "Open Spreadsheet" window does not show the file. See my twitter stream for the desktop screenshot, http://t.co/QBoaWPxihh
Date Time Of Last Edit: 2013-06-22 19:10:56
[2013-06-23 00:18:15] |
Sawtooth - Posts: 3993 |
Two issues: 1) It appears the Sierra installation you are using is not the one at C:\SierraChart\Data. Go to Global Settings >> General Settings and note the location of the Data Files Folder, then put the spreadsheet in that folder. 2) The ZZ CD Delta.scwbf is meant to be used with a study collection so that the correct spreadsheet study, zigzag, and CD bars study is added to the chart, with the correct settings. Use the attached study collection (put it in the \Data folder also). |
ZZ CD Delta-.StdyCollct - Attached On 2013-06-23 00:15:29 UTC - Size: 27.98 KB - 519 views |
