Date/Time: Sun, 19 May 2024 00:38:01 +0000
Missing chart data
View Count: 610
[2015-12-10 08:00:56] |
User417540 - Posts: 13 |
Hi . This seems to be happening daily now. Using AMP/CQG and get missing intraday data. Is there a fix for this or do I need to contact AMP? thanks
UploadImage.png / V - Attached On 2015-12-10 08:00:03 UTC - Size: 41.84 KB - 229 views Attachment Deleted. |
[2015-12-10 09:00:41] |
We apologize for this. The missing data has now been added and we have now contacted CQG about this problem. Follow the instructions here to download the missing data: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart If this problem continues, we have another solution we can implement. However, we want to see if CQG can remedy the problem first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
