Date/Time: Sat, 18 May 2024 06:22:31 +0000
CQG connection problem
View Count: 781
[2015-12-09 16:17:13] |
User11942 - Posts: 298 |
Hello SC team, something is going wrong with the connection to CQG FIX, can't reconnect at all. The problem began appr. 10:40 AM Eastern, first data stopped coming thru and once disconnected can't connect anymore. Please find the quote below: CQG WebAPI websocket (432) | SSL connection failed. | 2015-12-09 11:05:51 CQG WebAPI websocket (432) | SSL object has been freed. SSL state is now disconnected. | 2015-12-09 11:05:51 CQG WebAPI websocket (432) | Shutdown and closed. | 2015-12-09 11:05:51 CQG FIX Trading | Websocket closed. | 2015-12-09 11:05:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:05:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:05:51 CQG FIX: DisconnectFIX called. | 2015-12-09 11:05:51 CQG FIX: Sending a Logout message. | 2015-12-09 11:05:51 CQG FIX Trading | Disconnected. | 2015-12-09 11:05:51 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:05:51 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:05:51 socket (431) | Shutdown and closed. | 2015-12-09 11:05:51 CQG FIX: Logged out and disconnected. | 2015-12-09 11:05:51 CQG FIX: Disconnected. | 2015-12-09 11:05:51 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:05:56 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:05:56 socket (433) | Connected. | 2015-12-09 11:05:56 CQG FIX: Sending the Logon message. | 2015-12-09 11:05:56 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:05:57 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:05:57 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:05:57 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:05:57 CQG FIX - FCM name: AMP | 2015-12-09 11:05:57 CQG WebAPI websocket (434) | Connected. | 2015-12-09 11:05:57 CQG WebAPI websocket (434) | Starting SSL 3/2 connection. | 2015-12-09 11:05:57 CQG WebAPI websocket (434) | SSL connection timed out. | 2015-12-09 11:06:02 * CQG WebAPI websocket (434) | SSL connection failed. | 2015-12-09 11:06:02 CQG WebAPI websocket (434) | SSL object has been freed. SSL state is now disconnected. | 2015-12-09 11:06:02 CQG WebAPI websocket (434) | Shutdown and closed. | 2015-12-09 11:06:02 CQG FIX Trading | Websocket closed. | 2015-12-09 11:06:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:06:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:06:02 CQG FIX: DisconnectFIX called. | 2015-12-09 11:06:02 CQG FIX: Sending a Logout message. | 2015-12-09 11:06:02 CQG FIX Trading | Disconnected. | 2015-12-09 11:06:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:06:02 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:06:03 socket (433) | Shutdown and closed. | 2015-12-09 11:06:03 CQG FIX: Logged out and disconnected. | 2015-12-09 11:06:03 CQG FIX: Disconnected. | 2015-12-09 11:06:03 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:06:07 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:06:07 socket (436) | Connected. | 2015-12-09 11:06:08 CQG FIX: Sending the Logon message. | 2015-12-09 11:06:08 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:06:08 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:06:08 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:06:08 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:06:08 CQG FIX - FCM name: AMP | 2015-12-09 11:06:08 CQG WebAPI websocket (437) | Connected. | 2015-12-09 11:06:08 CQG WebAPI websocket (437) | Starting SSL 3/2 connection. | 2015-12-09 11:06:08 CQG WebAPI websocket (437) | SSL connection timed out. | 2015-12-09 11:06:14 * CQG WebAPI websocket (437) | SSL connection failed. | 2015-12-09 11:06:14 CQG WebAPI websocket (437) | SSL object has been freed. SSL state is now disconnected. | 2015-12-09 11:06:14 CQG WebAPI websocket (437) | Shutdown and closed. | 2015-12-09 11:06:14 CQG FIX Trading | Websocket closed. | 2015-12-09 11:06:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:06:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:06:14 CQG FIX: DisconnectFIX called. | 2015-12-09 11:06:14 CQG FIX: Sending a Logout message. | 2015-12-09 11:06:14 CQG FIX Trading | Disconnected. | 2015-12-09 11:06:14 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:06:14 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:06:14 socket (436) | Shutdown and closed. | 2015-12-09 11:06:14 CQG FIX: Logged out and disconnected. | 2015-12-09 11:06:14 CQG FIX: Disconnected. | 2015-12-09 11:06:14 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:06:19 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:06:19 socket (438) | Connected. | 2015-12-09 11:06:19 CQG FIX: Sending the Logon message. | 2015-12-09 11:06:19 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:06:19 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:06:19 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:06:19 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:06:19 CQG FIX - FCM name: AMP | 2015-12-09 11:06:20 CQG WebAPI websocket (439) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-12-09 11:06:33 CQG WebAPI websocket (439) | Shutdown and closed. | 2015-12-09 11:06:33 CQG FIX Trading | Websocket closed. | 2015-12-09 11:06:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:06:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:06:33 CQG FIX: DisconnectFIX called. | 2015-12-09 11:06:33 CQG FIX: Sending a Logout message. | 2015-12-09 11:06:33 CQG FIX Trading | Disconnected. | 2015-12-09 11:06:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:06:33 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:06:33 socket (438) | Shutdown and closed. | 2015-12-09 11:06:33 CQG FIX: Logged out and disconnected. | 2015-12-09 11:06:33 CQG FIX: Disconnected. | 2015-12-09 11:06:33 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:06:38 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:06:38 socket (440) | Connected. | 2015-12-09 11:06:38 CQG FIX: Sending the Logon message. | 2015-12-09 11:06:38 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:06:39 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:06:39 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:06:39 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:06:39 CQG FIX - FCM name: AMP | 2015-12-09 11:06:39 CQG WebAPI websocket (441) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:06:45 CQG WebAPI websocket (441) | Shutdown and closed. | 2015-12-09 11:06:45 CQG FIX Trading | Websocket closed. | 2015-12-09 11:06:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:06:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:06:45 CQG FIX: DisconnectFIX called. | 2015-12-09 11:06:45 CQG FIX: Sending a Logout message. | 2015-12-09 11:06:45 CQG FIX Trading | Disconnected. | 2015-12-09 11:06:45 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:06:45 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:06:46 socket (440) | Shutdown and closed. | 2015-12-09 11:06:46 CQG FIX: Logged out and disconnected. | 2015-12-09 11:06:46 CQG FIX: Disconnected. | 2015-12-09 11:06:46 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:06:50 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:06:50 socket (442) | Connected. | 2015-12-09 11:06:51 CQG FIX: Sending the Logon message. | 2015-12-09 11:06:51 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:06:51 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:06:51 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:06:51 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:06:51 CQG FIX - FCM name: AMP | 2015-12-09 11:06:51 CQG WebAPI websocket (443) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:06:58 CQG WebAPI websocket (443) | Shutdown and closed. | 2015-12-09 11:06:58 CQG FIX Trading | Websocket closed. | 2015-12-09 11:06:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:06:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:06:58 CQG FIX: DisconnectFIX called. | 2015-12-09 11:06:58 CQG FIX: Sending a Logout message. | 2015-12-09 11:06:59 CQG FIX Trading | Disconnected. | 2015-12-09 11:06:59 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:06:59 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:06:59 socket (442) | Shutdown and closed. | 2015-12-09 11:06:59 CQG FIX: Logged out and disconnected. | 2015-12-09 11:06:59 CQG FIX: Disconnected. | 2015-12-09 11:06:59 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:07:04 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:07:04 socket (444) | Connected. | 2015-12-09 11:07:04 CQG FIX: Sending the Logon message. | 2015-12-09 11:07:04 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:07:04 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:07:04 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:07:04 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:07:04 CQG FIX - FCM name: AMP | 2015-12-09 11:07:04 CQG WebAPI websocket (445) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-12-09 11:07:17 CQG WebAPI websocket (445) | Shutdown and closed. | 2015-12-09 11:07:17 CQG FIX Trading | Websocket closed. | 2015-12-09 11:07:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:07:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:07:17 CQG FIX: DisconnectFIX called. | 2015-12-09 11:07:17 CQG FIX: Sending a Logout message. | 2015-12-09 11:07:17 CQG FIX Trading | Disconnected. | 2015-12-09 11:07:17 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:07:17 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:07:18 socket (444) | Shutdown and closed. | 2015-12-09 11:07:18 CQG FIX: Logged out and disconnected. | 2015-12-09 11:07:18 CQG FIX: Disconnected. | 2015-12-09 11:07:18 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:07:22 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:07:22 socket (446) | Connected. | 2015-12-09 11:07:23 CQG FIX: Sending the Logon message. | 2015-12-09 11:07:23 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:07:23 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:07:23 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:07:23 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:07:23 CQG FIX - FCM name: AMP | 2015-12-09 11:07:23 CQG WebAPI websocket (447) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:07:25 CQG WebAPI websocket (447) | Shutdown and closed. | 2015-12-09 11:07:25 CQG FIX Trading | Websocket closed. | 2015-12-09 11:07:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:07:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:07:25 CQG FIX: DisconnectFIX called. | 2015-12-09 11:07:25 CQG FIX: Sending a Logout message. | 2015-12-09 11:07:25 CQG FIX Trading | Disconnected. | 2015-12-09 11:07:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:07:25 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:07:25 socket (446) | Shutdown and closed. | 2015-12-09 11:07:25 CQG FIX: Logged out and disconnected. | 2015-12-09 11:07:25 CQG FIX: Disconnected. | 2015-12-09 11:07:25 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:07:30 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:07:30 socket (448) | Connected. | 2015-12-09 11:07:30 CQG FIX: Sending the Logon message. | 2015-12-09 11:07:30 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:07:30 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:07:30 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:07:30 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:07:30 CQG FIX - FCM name: AMP | 2015-12-09 11:07:30 CQG WebAPI websocket (449) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-12-09 11:07:44 CQG WebAPI websocket (449) | Shutdown and closed. | 2015-12-09 11:07:44 CQG FIX Trading | Websocket closed. | 2015-12-09 11:07:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:07:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:07:44 CQG FIX: DisconnectFIX called. | 2015-12-09 11:07:44 CQG FIX: Sending a Logout message. | 2015-12-09 11:07:44 CQG FIX Trading | Disconnected. | 2015-12-09 11:07:44 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:07:44 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:07:44 socket (448) | Shutdown and closed. | 2015-12-09 11:07:44 CQG FIX: Logged out and disconnected. | 2015-12-09 11:07:44 CQG FIX: Disconnected. | 2015-12-09 11:07:44 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:07:49 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:07:49 socket (450) | Connected. | 2015-12-09 11:07:49 CQG FIX: Sending the Logon message. | 2015-12-09 11:07:49 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:07:49 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:07:49 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:07:49 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:07:49 CQG FIX - FCM name: AMP | 2015-12-09 11:07:49 CQG WebAPI websocket (451) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-12-09 11:08:03 CQG WebAPI websocket (451) | Shutdown and closed. | 2015-12-09 11:08:03 CQG FIX Trading | Websocket closed. | 2015-12-09 11:08:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:03 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:03 CQG FIX: Sending a Logout message. | 2015-12-09 11:08:03 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:03 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:03 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:08:03 socket (450) | Shutdown and closed. | 2015-12-09 11:08:03 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:03 CQG FIX: Disconnected. | 2015-12-09 11:08:03 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:08 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:08 socket (453) | Connected. | 2015-12-09 11:08:08 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:08 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:08:08 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:08:08 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:08:08 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:08:08 CQG FIX - FCM name: AMP | 2015-12-09 11:08:08 CQG WebAPI websocket (454) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:08:15 CQG WebAPI websocket (454) | Shutdown and closed. | 2015-12-09 11:08:15 CQG FIX Trading | Websocket closed. | 2015-12-09 11:08:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:15 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:15 CQG FIX: Sending a Logout message. | 2015-12-09 11:08:15 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:15 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:15 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:08:15 socket (453) | Shutdown and closed. | 2015-12-09 11:08:15 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:15 CQG FIX: Disconnected. | 2015-12-09 11:08:15 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:20 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:20 socket (455) | Connected. | 2015-12-09 11:08:20 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:20 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:21 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:21 socket (455) | Shutdown and closed. | 2015-12-09 11:08:21 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:21 CQG FIX: Disconnected. | 2015-12-09 11:08:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:21 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:21 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:21 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:21 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:26 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:26 socket (456) | Connected. | 2015-12-09 11:08:26 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:26 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:26 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:26 socket (456) | Shutdown and closed. | 2015-12-09 11:08:26 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:26 CQG FIX: Disconnected. | 2015-12-09 11:08:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:26 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:26 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:26 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:26 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:31 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:31 socket (457) | Connected. | 2015-12-09 11:08:31 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:32 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:32 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:32 socket (457) | Shutdown and closed. | 2015-12-09 11:08:32 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:32 CQG FIX: Disconnected. | 2015-12-09 11:08:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:32 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:32 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:32 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:32 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:37 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:37 socket (458) | Connected. | 2015-12-09 11:08:37 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:37 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:37 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:37 socket (458) | Shutdown and closed. | 2015-12-09 11:08:37 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:37 CQG FIX: Disconnected. | 2015-12-09 11:08:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:37 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:37 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:37 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:37 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:42 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:42 socket (459) | Connected. | 2015-12-09 11:08:43 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:43 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:43 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:43 socket (459) | Shutdown and closed. | 2015-12-09 11:08:43 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:43 CQG FIX: Disconnected. | 2015-12-09 11:08:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:43 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:43 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:43 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:43 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:48 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:48 socket (460) | Connected. | 2015-12-09 11:08:48 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:48 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:49 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:49 socket (460) | Shutdown and closed. | 2015-12-09 11:08:49 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:49 CQG FIX: Disconnected. | 2015-12-09 11:08:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:49 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:49 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:49 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:54 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:54 socket (461) | Connected. | 2015-12-09 11:08:54 CQG FIX: Sending the Logon message. | 2015-12-09 11:08:54 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:08:54 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:08:54 socket (461) | Shutdown and closed. | 2015-12-09 11:08:54 CQG FIX: Logged out and disconnected. | 2015-12-09 11:08:54 CQG FIX: Disconnected. | 2015-12-09 11:08:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:08:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:08:54 CQG FIX: DisconnectFIX called. | 2015-12-09 11:08:54 CQG FIX Trading | Disconnected. | 2015-12-09 11:08:54 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:08:54 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:08:59 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:08:59 socket (462) | Connected. | 2015-12-09 11:09:00 CQG FIX: Sending the Logon message. | 2015-12-09 11:09:00 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:09:00 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:09:00 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:09:00 CQG FIX - FCM name: AMP | 2015-12-09 11:09:00 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:09:00 CQG WebAPI websocket (463) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:09:07 CQG WebAPI websocket (463) | Shutdown and closed. | 2015-12-09 11:09:07 CQG FIX Trading | Websocket closed. | 2015-12-09 11:09:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:09:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:09:07 CQG FIX: DisconnectFIX called. | 2015-12-09 11:09:07 CQG FIX: Sending a Logout message. | 2015-12-09 11:09:07 CQG FIX Trading | Disconnected. | 2015-12-09 11:09:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:09:07 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:09:07 socket (462) | Shutdown and closed. | 2015-12-09 11:09:08 CQG FIX: Logged out and disconnected. | 2015-12-09 11:09:08 CQG FIX: Disconnected. | 2015-12-09 11:09:08 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:09:12 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:09:12 socket (464) | Connected. | 2015-12-09 11:09:13 CQG FIX: Sending the Logon message. | 2015-12-09 11:09:13 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:09:13 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:09:13 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:09:13 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:09:13 CQG FIX - FCM name: AMP | 2015-12-09 11:09:13 CQG WebAPI websocket (465) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:09:20 CQG WebAPI websocket (465) | Shutdown and closed. | 2015-12-09 11:09:20 CQG FIX Trading | Websocket closed. | 2015-12-09 11:09:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:09:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:09:20 CQG FIX: DisconnectFIX called. | 2015-12-09 11:09:20 CQG FIX: Sending a Logout message. | 2015-12-09 11:09:20 CQG FIX Trading | Disconnected. | 2015-12-09 11:09:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:09:20 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:09:20 socket (464) | Shutdown and closed. | 2015-12-09 11:09:20 CQG FIX: Logged out and disconnected. | 2015-12-09 11:09:20 CQG FIX: Disconnected. | 2015-12-09 11:09:20 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:09:25 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:09:25 socket (466) | Connected. | 2015-12-09 11:09:25 CQG FIX: Sending the Logon message. | 2015-12-09 11:09:25 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:09:26 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:09:26 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:09:26 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:09:26 CQG FIX - FCM name: AMP | 2015-12-09 11:09:26 CQG WebAPI websocket (467) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-12-09 11:09:39 CQG WebAPI websocket (467) | Shutdown and closed. | 2015-12-09 11:09:39 CQG FIX Trading | Websocket closed. | 2015-12-09 11:09:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:09:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:09:39 CQG FIX: DisconnectFIX called. | 2015-12-09 11:09:39 CQG FIX: Sending a Logout message. | 2015-12-09 11:09:39 CQG FIX Trading | Disconnected. | 2015-12-09 11:09:39 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:09:39 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:09:39 socket (466) | Shutdown and closed. | 2015-12-09 11:09:39 CQG FIX: Logged out and disconnected. | 2015-12-09 11:09:39 CQG FIX: Disconnected. | 2015-12-09 11:09:39 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:09:44 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:09:44 socket (468) | Connected. | 2015-12-09 11:09:44 CQG FIX: Sending the Logon message. | 2015-12-09 11:09:44 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:09:45 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:09:45 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:09:45 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:09:45 CQG FIX - FCM name: AMP | 2015-12-09 11:09:45 CQG WebAPI websocket (469) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:09:46 CQG WebAPI websocket (469) | Shutdown and closed. | 2015-12-09 11:09:46 CQG FIX Trading | Websocket closed. | 2015-12-09 11:09:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:09:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:09:46 CQG FIX: DisconnectFIX called. | 2015-12-09 11:09:46 CQG FIX: Sending a Logout message. | 2015-12-09 11:09:46 CQG FIX Trading | Disconnected. | 2015-12-09 11:09:46 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:09:46 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:09:46 socket (468) | Shutdown and closed. | 2015-12-09 11:09:46 CQG FIX: Logged out and disconnected. | 2015-12-09 11:09:46 CQG FIX: Disconnected. | 2015-12-09 11:09:46 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:09:51 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:09:51 socket (470) | Connected. | 2015-12-09 11:09:51 CQG FIX: Sending the Logon message. | 2015-12-09 11:09:51 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:09:52 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:09:52 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:09:52 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:09:52 CQG FIX - FCM name: AMP | 2015-12-09 11:09:52 CQG WebAPI websocket (471) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:09:53 CQG WebAPI websocket (471) | Shutdown and closed. | 2015-12-09 11:09:53 CQG FIX Trading | Websocket closed. | 2015-12-09 11:09:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:09:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:09:53 CQG FIX: DisconnectFIX called. | 2015-12-09 11:09:53 CQG FIX: Sending a Logout message. | 2015-12-09 11:09:53 CQG FIX Trading | Disconnected. | 2015-12-09 11:09:53 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:09:53 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:09:53 socket (470) | Shutdown and closed. | 2015-12-09 11:09:53 CQG FIX: Logged out and disconnected. | 2015-12-09 11:09:53 CQG FIX: Disconnected. | 2015-12-09 11:09:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:09:58 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:09:58 socket (472) | Connected. | 2015-12-09 11:09:58 CQG FIX: Sending the Logon message. | 2015-12-09 11:09:59 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2015-12-09 11:09:59 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2015-12-09 11:09:59 socket (472) | Shutdown and closed. | 2015-12-09 11:09:59 CQG FIX: Logged out and disconnected. | 2015-12-09 11:09:59 CQG FIX: Disconnected. | 2015-12-09 11:09:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:09:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:09:59 CQG FIX: DisconnectFIX called. | 2015-12-09 11:09:59 CQG FIX Trading | Disconnected. | 2015-12-09 11:09:59 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:09:59 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:10:04 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:10:04 socket (474) | Connected. | 2015-12-09 11:10:04 CQG FIX: Sending the Logon message. | 2015-12-09 11:10:05 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:10:05 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:10:05 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:10:05 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:10:05 CQG FIX - FCM name: AMP | 2015-12-09 11:10:05 CQG WebAPI websocket (475) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:10:07 CQG WebAPI websocket (475) | Shutdown and closed. | 2015-12-09 11:10:07 CQG FIX Trading | Websocket closed. | 2015-12-09 11:10:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:10:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:10:07 CQG FIX: DisconnectFIX called. | 2015-12-09 11:10:07 CQG FIX: Sending a Logout message. | 2015-12-09 11:10:07 CQG FIX Trading | Disconnected. | 2015-12-09 11:10:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:10:07 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:10:07 socket (474) | Shutdown and closed. | 2015-12-09 11:10:07 CQG FIX: Logged out and disconnected. | 2015-12-09 11:10:07 CQG FIX: Disconnected. | 2015-12-09 11:10:07 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:10:12 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:10:12 socket (476) | Connected. | 2015-12-09 11:10:12 CQG FIX: Sending the Logon message. | 2015-12-09 11:10:13 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:10:13 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:10:13 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:10:13 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:10:13 CQG FIX - FCM name: AMP | 2015-12-09 11:10:13 CQG WebAPI websocket (477) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:10:15 CQG WebAPI websocket (477) | Shutdown and closed. | 2015-12-09 11:10:15 CQG FIX Trading | Websocket closed. | 2015-12-09 11:10:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:10:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:10:15 CQG FIX: DisconnectFIX called. | 2015-12-09 11:10:15 CQG FIX: Sending a Logout message. | 2015-12-09 11:10:15 CQG FIX Trading | Disconnected. | 2015-12-09 11:10:15 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:10:15 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:10:15 socket (476) | Shutdown and closed. | 2015-12-09 11:10:15 CQG FIX: Logged out and disconnected. | 2015-12-09 11:10:15 CQG FIX: Disconnected. | 2015-12-09 11:10:15 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 11:13:15 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 11:13:15 socket (479) | Connected. | 2015-12-09 11:13:15 CQG FIX: Sending the Logon message. | 2015-12-09 11:13:15 CQG FIX Trading | Connected to trading server. | 2015-12-09 11:13:15 CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 11:13:15 CQG WebAPI | Connecting to websocket server. | 2015-12-09 11:13:15 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 11:13:15 CQG FIX - FCM name: AMP | 2015-12-09 11:13:15 CQG WebAPI websocket (480) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 11:13:17 CQG WebAPI websocket (480) | Shutdown and closed. | 2015-12-09 11:13:17 CQG FIX Trading | Websocket closed. | 2015-12-09 11:13:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 11:13:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 11:13:17 CQG FIX: DisconnectFIX called. | 2015-12-09 11:13:17 CQG FIX: Sending a Logout message. | 2015-12-09 11:13:17 CQG FIX Trading | Disconnected. | 2015-12-09 11:13:17 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-09 11:13:17 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 11:13:17 socket (479) | Shutdown and closed. | 2015-12-09 11:13:17 CQG FIX: Logged out and disconnected. | 2015-12-09 11:13:17 CQG FIX: Disconnected. | 2015-12-09 11:13:17 |
[2015-12-09 16:36:32] |
The CQG server is now working.
