Date/Time: Sat, 27 Apr 2024 15:13:36 +0000
Fibonacci Fans/Retracement Lines
View Count: 1483
[2013-06-21 20:46:34] |
User29707 - Posts: 43 |
Does SC provide Fibonacci retracement levels (horizontal lines with levels)? I see the fans, is this all SC provides?
[2013-06-21 21:24:19] |
Yes. Here is the documentation for these tools: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-21 22:37:00] |
Do you provide Horizontal Fib levels, not fans?
[2013-06-21 22:42:35] |
We apologize, we should have given you a direct link to the Price Retracement, Expansion and Projection tools: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#RetracementExpansionProjection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
