Date/Time: Mon, 20 May 2024 16:21:37 +0000
Number of Trades Problem
View Count: 787
[2015-12-07 13:54:12] |
User96015 - Posts: 55 |
Dear sir. I found a problem with Number of Trades study. As you can see in the attachment, the sum of NTrade of Bid and Ask doesn' t matches with total of number of trades of the bar. Please let me know. Thanks. Bye. P.S.: Rithmic Data feed Date Time Of Last Edit: 2015-12-07 13:54:26
NTrade Problem.png / V - Attached On 2015-12-07 13:53:57 UTC - Size: 28.46 KB - 276 views |
[2015-12-07 17:10:58] |
Follow the instructions here to use a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php The documentation does explain that for these studies: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s275 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
