Date/Time: Sun, 19 May 2024 07:23:49 +0000
Stocks
View Count: 699
[2015-12-07 02:22:09] |
User638756 - Posts: 52 |
I know you can use SC for stocks, can you use the DOM for the execution? If not, what would I use for the executions?
[2015-12-07 02:41:36] |
Yes you can use the Trading Ladder/DOM for order entry.
