Date/Time: Sat, 18 May 2024 08:17:05 +0000
volume and RSI studies
View Count: 842
[2015-12-07 01:17:02] |
User638756 - Posts: 52 |
http://www.sierrachart.com/image.php?l=144945079167.png Is there a way to put the RSI (the bottom study) with just 1 line? Is there a way to put the volume on chart region one and make it transparent or some way it doesnt interfere with the candlesticks? |
[2015-12-07 01:27:35] |
1. You need to set the Draw Style for the Subgraph lines you do not want to display to "Ignore". This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle 2. Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#OverlayingStudyOnMainPriceGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-07 01:34:47] |
Do you know what line I set to ignore to make it the standard RSI? Thanks |
[2015-12-07 01:38:09] |
You would set the Draw Style for all of the lines to Ignore other than the Subgraph named RSI.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-07 01:38:25
[2015-12-09 05:48:40] |
http://www.sierrachart.com/image.php?l=1449639941911.png Im having a hard time putting the volume in chart region 1 without it overlapping with the candlesticks |
[2015-12-09 06:23:03] |
What we see in the chart image posted, looks correct and there is no easy way to change that.
