Date/Time: Sun, 19 May 2024 02:18:18 +0000
Stop-Limit Orders
View Count: 756
[2015-12-06 12:32:38] |
User34947 - Posts: 42 |
I would like to know if the following is supported. In the case of a Buy Stop-Limit Order, if the price for example reaches 100 then a Limit Order is sent at 99 (Stop-Limit Order Limit Offset has to be negative in such case?) Thank you. |
[2015-12-06 21:22:43] |
We see you are using Rithmic. This is not supported. A negative offset will not work.
