Date/Time: Sat, 18 May 2024 20:20:48 +0000
Difference AMP / SC Realtime datafeed
View Count: 698
[2015-12-06 08:08:01] |
tobi - Posts: 351 |
Is there a difference between the datafeed delivered by AMP and SC Relatime Data Feed in regard to quality, speed etc.? What are the differences? |
[2015-12-06 09:31:59] |
AMP does not provide any data feeds. They use CQG, Rithmic, and TT FIX. In general your question is hard to answer, but overall you will have more reliability by using the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
