Date/Time: Sun, 19 May 2024 08:28:26 +0000
Order windows when Tiling Vertically
View Count: 722
[2015-12-04 18:39:59] |
San4x - Posts: 4 |
Hi, I have read the instructions and re-ordered my windows using the Window -> Windows & Chartbooks command. Whatever I do, I can not get USOil to behave, all other assets work fine. I wonder why. My objective is to have the USOil chart placed second when tiling vertically, so in the left bottom corner. I have placed USOil second in the list, but whenever I reorder the charts, going from WTH to WTV for example, the USOil chart is not placed in the order it should. I've uploaded a screenshot here, unfortunately I could not have the Windows & Chartbooks window visible as well to show you the order. However, you can see the order of the charts on the bottom as well. http://www.sierrachart.com/image.php?l=1449254380255.png Thanks in advance for any tips..! |
2015-12-04_14-31-47.png / V - Attached On 2015-12-04 18:33:15 UTC - Size: 201.62 KB - 258 views |
[2015-12-04 19:09:44] |
In the screenshot you attached, the chart you are pointing to with the arrows is not the same chart. You can tell by looking at the Chart Number #. Notice it is a different Chart Number. Therefore, the chart that is the second in the list is probably minimized. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-04 19:29:21] |
San4x - Posts: 4 |
Oops, you are so right it's embarrassing I did not catch/check that. Thanks so much, all good now. |
