Date/Time: Sun, 19 May 2024 02:34:51 +0000
custom time periods
View Count: 653
[2015-12-04 17:56:16] |
michelh - Posts: 159 |
Hi SC, I use some time periods such as 2 day, 3 day, 10 day, 14 day in addition to the conventional periods. I want to put these in the toolbar, and when I do they come up as intraday charts and not historical charts. so, the 2day button on my toolbar acutally loads an intraday 2 day chart and not a 2 day historical chart. Given that intraday data for most contracts is limited, I get a very limited chart. So i have to in manually and change the chart settings to historical and 2 day. Unfortunately, you do not currently have the option to use historical chart custom time periods in your toolbar. You only have intraday options. If this could be accommodated, I would greatly appreciate it since it is rather tedious to always change the chart settings. |
[2015-12-04 18:29:31] |
You can change the number of days per bar for a Historical Chart directly through the keyboard without opening the Chart Settings window. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChangingPeriodOfBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
