Date/Time: Sun, 19 May 2024 04:11:56 +0000
Add a limit order for active trade chart trade
View Count: 670
[2015-12-04 16:47:07] |
User515532 - Posts: 19 |
If I open a trade (qty 2) without a target and wanted to add the target later, how to add and have it shown on the chart?
[2015-12-04 17:51:59] |
You just simply submit the Limit order using the Chart Trading functionality: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#EnteringOrdersFromTheChart We assume that there is already an actual Position with quantity 2? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-04 17:52:09
[2015-12-04 19:15:50] |
Yes, there is already a position qith 1 qty. So which setting should be used to add the targets and by left click of the mouse? Please be more specific.
[2015-12-04 19:35:51] |
Actually if you already have the Attached Orders defined on the Targets tab, then follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#SendAttachedOrders Also the documentation we linked to in the prior post from us is very specific on how to submit an order from the chart. We would not repeat that information here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
