Date/Time: Sun, 19 May 2024 04:56:18 +0000
Is it possible to trade with Dukascopy
View Count: 1050
[2015-12-04 15:23:35] |
scotpip1 - Posts: 2 |
Hi We have a FIX account with Dukascopy. I know you have a FIX connector that can use Dukas as a data feed, but when I asked a couple of years back there was no way to place orders. Is this still the situation, or is it now possible to trade with Dukascopy through Sierra? |
[2015-12-04 17:53:15] |
Trading with Dukascopy is not supported but we could program that for an additional cost. Not sure exactly what it would be but it would be a minimum of about 500 USD.
[2015-12-04 22:40:51] |
Thanks We're evaluating options at the moment, and may get back in touch for a quote. |
[2015-12-04 23:13:36] |
OK. Please let us know. Letting you know Sierra Chart supports LMAX currently. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-04 23:13:52
