Date/Time: Sun, 05 May 2024 09:14:26 +0000
Does Sierra Charts have these indicators or something similar?
View Count: 5415
[2013-06-21 13:25:57] |
User76685 - Posts: 5 |
Hi there I recently done an options course with John Carter. You are probably familiar with the TTM Squeeze indicator? I found some old posts about SC having something similar to this indicator. Is that true? In conjunction with the setups he teaches he uses the TTM ABC Wave indicator (attached). Is this available on SC? I have not purchased the indicators from TTM, its too expensive in my view i.e. I either buy them and install it on SC OR see if SC can help me out with something similar! The last option I have is to switch brokers to TOS/Ameritrade which includes these indicators BUT I'm very happy with my current broker. Please share your input in this regard or point me to an alternative and hopefully free or cheap way of getting around this issue. Regards Richard |
[2013-06-21 15:53:39] |
M5amhan - Posts: 468 |
bollinger squeeze 2 is the original squeeze indicator made by john bollinger
[2013-06-21 16:48:25] |
Thanks for that. where do I get it and what about the wave indicator mentioned in my original post? |
[2013-06-21 16:55:50] |
its in the studies window, it comes with sierra. as far as any of the waves, they arent here.. fwiw, what i would do is just pick a momentum indicator that you like, change the draw style to bar then try to match the settings so it looks as close to the waves as possible.. look at one of his charts and pull up the same one and just try different settings until it is very similar. after all its just momentum, they want to sell it as something different but its not. or you could just buy it if you really need it. just my 2 cents |
[2013-06-21 17:05:15] |
Awesome I will try that thanks! Regards Richard |
[2013-06-21 23:32:34] |
One of the studies is in Analysis >> Studies. There are 2 Bollinger Squeeze studies.
[2013-06-21 23:34:44] |
The TTM wave studies are available for Sierra Chart if you do buy them from TTM.
