Date/Time: Sat, 04 May 2024 01:13:21 +0000
Can't remove position line from chart
View Count: 817
[2015-12-04 09:52:13] |
User156949 - Posts: 1 |
I have a persistent position line on a chart (UK 100). The Orders and Positions window (Ctrl-Shift-P) shows no orders or positions running. How do I remove the position line on the screen?
[2015-12-04 10:07:16] |
So you are using Sierra Chart Trade Simulation Mode? In that case simply press the Flatten button on the Trade Window for the chart: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OpeningTradeWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
