Date/Time: Sun, 19 May 2024 04:37:13 +0000
To align the Time Scale for Volume Per Bar chart with Time chart
View Count: 728
[2015-12-04 08:12:52] |
Riche - Posts: 20 |
I am using Sierra Chart version 1329. I am using both Volume per Bar chart and time chart. Question is how can i align the time for both chart so that the time scale for both charts are similar. For example the 5 min chart has 1st Dec till 4th Dec from end to end. Now i want the Volume per Bar chart to also have 1st Dec till 4th Dec from end to end. |
[2015-12-04 18:51:40] |
The only thing you can do is adjust the chart Bar Spacing to see if you can accomplish what you want: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing We have no further information to provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
