Date/Time: Mon, 06 May 2024 18:58:52 +0000
old spreadsheets with current version?
View Count: 752
[2015-12-03 17:39:56] |
rick e - Posts: 51 |
Is it possible to download the "Current Version" while still retaining the "old spreadsheets"? Thanks - Rick
[2015-12-03 18:20:39] |
Newer versions of Sierra Chart are no longer being updated with Old Spreadsheets. The latest version with old Spreadsheets is 1310. Let us know if you need a link to download that version. What we recommend doing is installing another copy of Sierra Chart on your system. Install the latest version. And gradually transition over in your available time to use New Spreadsheets in that new version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-03 18:21:55] |
We see you are using Interactive Brokers. We can make an exception in your case to not have to update, if you are not using Sierra Chart for trading. Are you doing any live trading from Sierra Chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-04 00:49:47] |
Sorry to take so long. Yes, I am using IB but if I place a trade I would just do it from IB itself. If you could make an exception, I would be very pleased. Thank you - Rick. I just don't have the time right now to try out the new spreadsheets - but I will in the future.
[2015-12-04 03:38:45] |
We will make an exception for your account.
