Date/Time: Sun, 19 May 2024 03:15:23 +0000
making attached order
View Count: 760
[2015-12-03 15:42:37] |
User638756 - Posts: 52 |
I want to make an attached order with 4 contracts, 3 with targets and the last one just floating around until I move the stop and it gets stopped out. Thanks |
[2015-12-04 04:18:10] |
Therefore, use the Attached Orders feature: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html You will need to add 3 Targets. Each of these needs to be in a separate OCO Group and the quantity of each of these needs to be 1. Add 1 Stop and set the OCO Group to "All OCO Groups". The above will work. Also, update to the latest release following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate As we were working on this request, we noticed a couple of user interface improvements that needed to be done for the Attached orders tab which have now been done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-04 04:19:06
[2015-12-06 22:18:46] |
http://www.sierrachart.com/image.php?l=1449440214906.png I did that and its still not working. I included a pic of the DOM. |
[2015-12-06 22:47:52] |
The Targets tab is set correctly. What is the specific problem? You can disregard the notice at the top of the Trade Window about there being a quantity mismatch because that is not going to matter in this case. You will still be able to submit the order with its Attached Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-06 23:25:26] |
Ok your right, it went thru (thanks!) . I put a sim trade on with it and 2 targets got hit and 1 did not, the order got stopped out but it didnt stop out the rest of the order even tho the oco group is all.
[2015-12-07 00:13:01] |
OK in that particular case you need to use 4 separate Stops each set to a Quantity of 1. Each one needs to use a separate OCO Group. Use 1 through 4.
