Date/Time: Tue, 07 May 2024 15:49:42 +0000
quote board insert ticker hot key
View Count: 616
[2015-12-03 14:20:32] |
User170575 - Posts: 221 |
Good morning, Is there a way to set the key or maybe one already to insert a ticker in a QB? Tx Cy |
[2015-12-03 17:56:41] |
This is not supported. However, you can left click with your Pointer 2 times in a cell in the Symbol column to put it into edit mode so you can manually type in a symbol.
