Date/Time: Fri, 03 May 2024 20:07:33 +0000
Data Not Updating for NQ-201512-Globex - SC Data Feed
View Count: 784
[2015-12-03 14:10:57] |
ged - Posts: 233 |
Most of the overnight data has not updated for the above symbol. Have followed the normal 'Delete and download' instructions.
[2015-12-03 14:23:13] |
ged - Posts: 233 |
Working now.
[2015-12-03 14:31:44] |
ged - Posts: 233 |
Data has frozen again!!
[2015-12-03 14:33:11] |
ged - Posts: 233 |
Restarted and again ok for now.
[2015-12-03 17:48:35] |
Do you see a [M] indicator displayed after the symbol at the top of the chart to confirm you are receiving data from the Sierra Chart Exchange Data Feed?
[2015-12-03 17:55:24] |
ged - Posts: 233 |
Yes, I do see the M. I don't know what caused the problem, but glad it is working well now. |
