Date/Time: Fri, 03 May 2024 07:14:06 +0000
export values from zigzag tool to .csv/xlsx?
View Count: 976
[2015-12-03 08:58:43] |
User60518 - Posts: 106 |
Hello, Is it possible to export the values for the size of the swing in ticks/points displayed when using the zig zag tool (to .csv/.xlsx )? What I am hoping to do is get an idea of frequency over a set time period of swing sizes - i.e. most to least likely. Hope that makes sense. Cheers |
[2015-12-03 20:08:43] |
We will write up documentation for how to do this. It should be ready later today.
[2015-12-04 04:50:09] |
Here is the documentation for this: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetAdditionalInfo.html#ExportingSheetDataToTextFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-04 04:52:07] |
You also need to enable the Additional Output for Spreadsheets input with the study. Set it to Yes.
