Date/Time: Wed, 18 Nov 2026 08:46:59 +0000
Main Price Graph on region 2
View Count: 1795
| [2015-12-03 03:36:42] |
| rc7rader - Posts: 145 |
Is it possible to put the main price graph on region 2? I would like a spreadsheet study in region 1 and the main price graph in region 2 and another set of studies in region 3.
| [2015-12-03 03:47:31] |
Never mind. I found the answer.
| [2020-05-11 15:24:57] |
| hatry - Posts: 2 |
I'm trying to do this but can't figure out how. Would you mind sharing how you did it please?
| [2020-05-11 15:37:08] |
| hatry - Posts: 2 |
Figured it out. Chart Settings - Advanced Settings 1 - Chart Region (Bottom middle of page)
| [2020-05-12 00:25:14] |
Refer to the setting for the Chart Region for the Main Price Graph here: Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu) And then refer to the setting for a study to be put in a specific Region here: Chart Studies: Settings and Inputs Tab >> Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
