Date/Time: Mon, 06 May 2024 08:09:28 +0000
Autotrading Indicator
View Count: 775
[2015-12-02 18:12:39] |
User76735 - Posts: 12 |
Hello guys, I want to make an indicator automatic. The indicator need enter and exits position and take profit and stop loss. You know how can i do that ? My skill in programing is none. Do you have MACD automatic indicator ? Who can help me ? Thanks in advanc Victor |
[2015-12-02 18:45:24] |
This can be done fairly easily by using the Spreadsheet System for Trading study which is documented on this page: http://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-03 15:04:01] |
Ok thanks but I dont have experience in spreadsheet. Do you have an example of another indicators or one example to start ?
[2015-12-03 18:40:28] |
You will have to take the time to learn about spreadsheets. There is no other way. There is already step-by-step instructions given there with a complete example.
