Date/Time: Mon, 29 Apr 2024 06:08:25 +0000
New bar on chart event
View Count: 757
[2015-12-02 12:17:44] |
User98049 - Posts: 13 |
Hi Support, I understood that if i am putting sc.UpdateAlways = 1, to a study, the SC will will enter that study, everytime the price/volume changed, and also when a new bar is coming up. Do you have a flag that can tell me if a call to that study, is because if a new bar on the chart, and the others calls are only when a bar value is changing on the same bar? Or, in differant words, Hoe can i know when a new bar is on? Ariel |
[2015-12-02 18:41:06] |
When using sc.UpdateAlways, the study function is called at the Chart Update Interval in Global Settings >> General Settings. There is no reason given as to why the study function is called. You can always compare the previous value from sc.ArraySize to the current value. You can store the previous value into a persistent variable by using this function: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetPersistentInt Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-02 18:41:25
