Date/Time: Sun, 28 Apr 2024 16:34:40 +0000
Volume Bar Studies - Calculation Query
View Count: 1335
[2013-06-21 10:03:39] |
User37170 - Posts: 29 |
I must decide if I want to upgrade my SC package and access the Number Bar and other studies but I need help in understanding/interpreting the following: 1] min ask vol - bid vol 2] askbid diff max to close diff 3] askbid diff min to close diff I attached the s/sheet into which I transcribed data drawn from a small candle & assoc. calcs The above 3 queries are clearly highlighted in GREY/ RED in the s/sheet A space is provided for correct data. Hope someone can assist. |
volBar Study example.xls - Attached On 2013-06-21 10:02:18 UTC - Size: 30.5 KB - 480 views |
[2013-06-21 18:46:00] |
These are documented on this page here: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#NumericInformationBelowBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-21 19:07:50] |
Hmm ! I have read the documentation many times. So doubt it will help. Any other info source you can suggest. |
