Date/Time: Sun, 19 May 2024 03:47:54 +0000
[User Discussion] - ATR Bands
View Count: 7936
[2013-06-21 08:34:35] |
User20851 - Posts: 9 |
Hello, I was wondering if it is possible, using SC's existing indicators, to set up the ATR Bands indicator as described in Active Trader magazine, July, 2013: "Trading with ATR Bands," but Julie Dahlquist. The upper band is an MA plus the ATR, the middle line is the MA itself, and the lower line is the MA minus the ATR. I think it would be nice if several MAs were available to choose from, although in the article, Dahlquist uses an SMA. If possible, perhaps this could be included as a self-contained study if there is enough interest. Thank you, and I hope to have the chance to try this out with SC. |
[2013-06-21 13:14:17] |
Sawtooth - Posts: 4000 |
You could create the band using the Study Subgraphs Add and Study Subgraphs Difference studies.
Date Time Of Last Edit: 2013-06-21 13:16:25
[2013-06-21 15:52:24] |
M5amhan - Posts: 468 |
what you are describing sounds very much like keltner channels http://stockcharts.com/school/doku.php?id=chart_school:technical_indicators:keltner_channels if you only want one ATR deviation (which would be the ATR) then use 1 as the multiplier |
[2013-06-22 19:44:58] |
vegasfoster - Posts: 444 |
Lets you use any moving average as centerline with BB or Keltner(ATR).
VolatilityBands.dll - Attached On 2013-06-22 19:44:52 UTC - Size: 81 KB - 654 views |
[2013-06-23 05:00:08] |
StevieD - Posts: 39 |
"The upper band is an MA plus the ATR, the middle line is the MA itself, and the lower line is the MA minus the ATR. I think it would be nice if several MAs were available to choose from" As requested. |
SCMisc.dll - Attached On 2013-06-23 04:58:26 UTC - Size: 45.5 KB - 622 views ATRBands.cpp - Attached On 2013-06-23 04:58:42 UTC - Size: 3.91 KB - 793 views |
[2013-06-23 22:32:34] |
Thank you all very much! As a new user of Sierra Chart, I'm not sure how to get custom indicators to display on a chart. What is the process? Thank you! |
[2013-06-30 18:35:04] |
Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-17 20:22:45] |
User57562 - Posts: 98 |
Interesting. Could someone do similar for APZ = Adaptive Price Zone? see http://www.investopedia.com/articles/trading/10/adaptive-price-zone-indicator-explained.asp and APZ mentioned http://forum.vtsystems.com/index.php?showtopic=4862 how to code for VTsystems. |
[2014-08-17 20:32:15] |
crazybears - Posts: 314 |
do you mean this ? http://www.traders.com/Documentation/FEEDbk_docs/2006/09/TradersTips/TradersTips.html#amibroker |
[2014-08-17 20:39:18] |
That looks like it. Now how to do on Sierra Chart?
