Date/Time: Mon, 29 Apr 2024 01:59:16 +0000
Ratio Bar study
View Count: 1007
[2015-12-01 18:16:03] |
rhovega - Posts: 279 |
Could you please consider modifying the ratio bar study so the bars may be colored green/red in accordance to up/down state? Currently bars are all the same color. Thanks |
[2015-12-01 19:14:23] |
Refer to the documentation about this here: https://www.sierrachart.com/index.php?page=doc/doc_GraphDrawTypesColorSettings.php You need to enable Use Chart Graphics Settings for Subgraph Colors. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
