Date/Time: Sun, 05 May 2024 19:16:56 +0000
Tick Bar Countdown
View Count: 954
[2015-12-01 15:38:26] |
User937866 - Posts: 12 |
Is there a way to have a countdown timer somewhere on the chart for the current bar? I use a 610 tick bar to trade and would like to see how many ticks are left before the bar closes.
[2015-12-01 16:04:29] |
Sierra Chart - Max - Posts: 5605 |
You will need to add the Countdown Timer study to your chart: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s201 Refer to the Adding/Modifying Chart Studies instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support |
[2015-12-02 14:22:15] |
Thank you
