Date/Time: Thu, 02 May 2024 21:46:41 +0000
SC.BUYENTRY
View Count: 1070
[2015-12-01 09:01:04] |
User186676 - Posts: 1 |
New user here, im currently using spreadsheet system for trading and want to use ACSIL to customize entries. Do you have source code that would help direct me, the goal would be to use current buy entries in column K and sell entries in column M. Other basic functions would also need to be included that ive laid out below. sc.BuyEntry/sc.SellEntry sc.SupportReversals = true; sc.SendOrdersToTradeService = true; sc.AllowMultipleEntriesInSameDirection = false; |
[2015-12-01 09:48:54] |
For examples, refer to this section here: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#ExampleCode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
