Date/Time: Wed, 28 Oct 2026 08:38:57 +0000
Point and Figure Chart Requests
View Count: 1767
[2015-12-01 05:11:36]
User15414 - Posts: 20
I would like to request the point and figure charts use close only as an option and the ability to place 45 deg trend lines.
[2015-12-01 10:25:44]
We will see about this Point and Figure Chart request.
Also to draw a 45° line, refer to this section here:https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Angle
[2015-12-01 20:32:59]
So to get an accurate grid to place a 45 degree line on my point and figure chart with a box size of .0005 (5 pips) I would set currency value per tick to .0001 ( 1 pip) and value increment per bar to 5?
[2015-12-01 20:56:26]
What would you consider one unit of price? .0005?
[2015-12-01 22:28:18]
.0005 ( 5 pips ) is my box size for the point and figure. This is for forex.
I have set my tick size to .0001 ( 1 pip ) in chart settings >> main settings >> tick size:
Then I set currency value per tick to .0001 ( 1 pip ) in chart settings >> advanced 2 >> currency value per tick:
Finally I set value increment per bar in ticks to ( 5 ) in chart settings >> advanced 2 >> value increment per bar in ticks:
These seem to be the right settings for accurate 45's.
Also I am noticing that on my 3 box reversal chart I am getting
2 box reversals sometimes instead of 3 and this is happening on all my 3 box reversal charts. Attached file.
Date Time Of Last Edit: 2015-12-01 22:34:13
image2015-12-01_14-26-04.png / V - Attached On 2015-12-01 22:27:28 UTC - Size: 18.27 KB - 427 views
[2015-12-02 19:10:17]
Yes, those settings are correct for a 45° angle.
You cannot look at the number of boxes in a column to determine the reversal amount. What you see is normal. Here is the documentation for how the study works:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s140
If the study were to not allow a reversal until there are the number of boxes in a column which equals the reversal amount, there would never be a reversal under some conditions. It would not make any sense.
Date Time Of Last Edit: 2015-12-02 19:16:51
