Date/Time: Mon, 06 May 2024 09:49:01 +0000
How to change single chart intraday session times from previous duplicate
View Count: 722
[2015-11-30 23:03:23] |
User341070 - Posts: 13 |
Hi there I would like to know how to change a previously duplicated charts session times WITHOUT changing all the previous charts that I have within my work book. I have a number of Eurex charts up and looking to have an ES TPO chart and I have simply duplicated it from a Eurex chart and changed the timezone and session time manually however it changes all the Eurex charts I have up. I can't seem to find this information in the instruction pages. Could you kindly point me to the section where this is stipulated? Thanks Oliver |
[2015-12-01 04:16:42] |
It sounds like you are using the Chart Linking feature and have enabled the Session Times linking option. So disable that. Here is the documentation for Chart Linking: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber Also, here is the documentation for Session Times: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-01 04:17:06
