Date/Time: Fri, 03 May 2024 12:09:03 +0000
P&L column
View Count: 709
[2015-11-30 22:50:38] |
User638756 - Posts: 52 |
I am trying to set the P&L column to currency in the dom but its not showing, the "C" is showing in the main section but the "P" is showing in the ladder column part
[2015-12-01 05:10:01] |
You can left click on the Profit and Loss Label at the top of the Position Profit/Loss column to change the format: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOMPositionPLColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
