Date/Time: Mon, 29 Apr 2024 00:43:41 +0000
cumulative tick
View Count: 2497
[2013-03-27 19:10:54] |
mattb - Posts: 30 |
trying to figure out how to construct a simple cumulative tick chart with moving averages. simple 1 minute line graph will do. trying to recreate the chart i have attached. thanks C:\Users\Matt Barnette\Desktop\MM\2013-03-27_1404cumulative_tick.png |
2013-03-27_1404cumulative_tick.png / V - Attached On 2013-03-27 19:07:54 UTC - Size: 63.94 KB - 843 views Attachment Deleted. |
[2013-03-29 02:38:52] |
Look at using the Cumulative Sum of Study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s134 You can then base a Moving Average on the study: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
