Date/Time: Thu, 02 May 2024 05:31:32 +0000
'Ticks Per Volume Bar' in Volume Profiles
View Count: 707
[2015-11-30 19:18:32] |
User948305 - Posts: 21 |
for ES 5mins chart, I can't change it 1 tick, only 5 ticks is allowed. Do I miss anything? thanks. |
[2015-11-30 19:25:12] |
You need to set the Chart >> Chart Settings >> Volume at Price Multiplier to 1.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-30 19:25:29
[2015-11-30 19:27:19] |
thanks! it's fixed.
