Date/Time: Mon, 06 May 2024 22:17:50 +0000
Centering the wicks of the candlesticks
View Count: 752
[2015-11-29 07:51:22] |
User705691 - Posts: 22 |
Is there a way to center the wicks of the candlesticks when the Bar High-Low Up/Down is set to 2, and the Candlestick Up/Down Outline is set to 2? http://www.sierrachart.com/image.php?l=1448783224210.png The wicks appear to be off-centered. Thanks. Date Time Of Last Edit: 2015-11-29 07:56:00
[2015-11-29 18:22:35] |
No. Of course not. It is physically impossible.
