Date/Time: Mon, 29 Apr 2024 01:33:04 +0000
How do I remove blank records that kept reloading?
View Count: 704
[2015-11-27 14:51:51] |
FFTrader - Posts: 180 |
I have a 20 ticks Renko Chart for the GC futures contract. Rolling over from Decemember 2015 to February 2016 futures contract and I get the attached chart. I checked the data by scrolling and noticed there are "Blank Records" ... so I use Sierra Chart's delete records to delete those blank records. However, the chart kept reloading the blank records!? Erasing and reloading a batch of data or the entire set of data also did not work. What should I do? Date Time Of Last Edit: 2015-11-27 14:53:08
20151127 SC IB Blank Records.JPG / V - Attached On 2015-11-27 14:51:34 UTC - Size: 226.38 KB - 294 views |
[2015-11-27 15:36:41] |
Okay. Never mind. I fixed the problem by deleting ALL of my 2015 data and reloading them. Chart looks normal now. Also, I noticed before deleting, many of the records have an "Open" price of zero ... |
[2015-11-27 17:41:34] |
It is normal to see an Open price of 0 for single trade data records.
