Date/Time: Mon, 29 Apr 2024 06:10:45 +0000
Enhancement Request
View Count: 744
[2015-11-27 14:10:09] |
boogybren - Posts: 9 |
When opening a chartbook, it would be super handy to have the cursor dropped right in the search field for quick searching. Then once you found your chartbook, to have a single tab drop you into the list of chartbooks where you can use your up and down arrow keys to select the one you wish to open. After you select it, then be able to hit the enter key to open it.
[2015-11-27 18:15:21] |
We will see about this.
