Date/Time: Mon, 29 Apr 2024 07:17:41 +0000
use of sierra chart on two PCs
View Count: 776
[2015-11-27 07:04:57] |
User737065 - Posts: 23 |
Thank you for your information. I want to use it on my PC and on my notebook. When I try to login with both at the same time it is not possible to get data connection for both at the same time. Can you help me with this? Thank you, regards |
[2015-11-27 08:04:54] |
The limitation is that CQG only allows one connection at a time using a single username. This can be worked around, with the new DTC Server functionality in Sierra Chart. However, this will not be ready until a few more weeks. Please check back then. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-27 08:41:37] |
User353315 - Posts: 3 |
Thank you, will this DTC Server be ready this year? Regards |
[2015-11-27 08:44:36] |
It should be. We are actually working on it at this moment. It just needs more testing for trading, TLS support, and historical data support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-27 08:54:13] |
How can I get the information about the date of the releas or will it be an automatic update?
[2015-11-27 09:31:45] |
Check the What is New page: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Also if you do not see anything listed there check back with us in about a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
